Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Loss Of Blue Color
I have lost the color blue on my television. I am also seeing a strange red hue surrounding some images on the set. Does anyone have any idea what this could be?
Thanks a million i got a 54" RCA I had HD cables connect to the DVD-Recorder some how I aways got a blue screen but know you fix my problem.  Thanks a million know my 54" RCA works fine.
Posted on Oct 14, 2007
    President:
  • 1,284 Answers
The loss of blue could be one of 3 things. First of all if you are connected to a HD cable box or a HD sat. recvr. using component cables. Make sure the BLUE connection hasn't fallen out or is loose. The possibilities is the blue CRT (picture tube) itself or something in the blue CRT driving circuit.
Posted on Feb 26, 2007
  • Don
    Don Feb 26, 2007
    The red hue outline could just be convergence alignment needed.
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Have a Sanyo big screen tv but need need to adjust the color, to yellow!
Need to know if older set with picture tubes---turn color off--if yellow screen you have a loss of blue of some sort--red and green will give you a yellow screen. If set has the 3 picture tubes look inside in the lens to see if all 3 have a image---little or no blue means a problem there.
Oct 15, 2012 | Sanyo Televison & Video
Red blue hue on picture
ur color setting has certain problem. from ur remote control go to color setting and set ur req.color
Mar 10, 2012 | Televison & Video
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitsubishi wd 52525 lost greens and blues. only colors on screen are red hues.
This the classic symptom for component input wires being crossed. Check color coding on tv input and signal sourse. Green,Blue and Red wires must correspond. If ok Is the color off on the tv menu also. If so and wires are ok replace light engine.
Nov 03, 2009 | Televison & Video
Loss of red color and dual images
Ur convergence is dead,U know how to solders?Buy a convergence kit,use what in that kit.ur tv should be back to normal.This website have the convergence kit
Tv repair World.com.
Oct 21, 2009 | Hitachi 57F500 57" Rear Projection...
NO Blue Colors on any station/program
If you are using component video cablesm make sure the blue is connected from tv to source.
Oct 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
