I deleted my HP Solution Center. Is there a way to reinstall it?
  • 2,692 Answers
Download another copy:
Posted on Dec 09, 2008
Can't fax because the fax log is full and want to know how to erase
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
While typing cursor jumps of to different lines and different areas
If you are using the touch pad, try turn it off and using an USB mouse. I have found that my palm hits the touch pad and causes random cursor movements.
May 12, 2011 | HP Pavilion dv4000 Notebook
My HP Officejet 5610 All-in-one has a scanner problem. It was scanning documents fine. Due to some other problem, I had to uninstall and reinstall the entire program. Ever since I have reinstalled, the...
Some time reinstalling these drivers and reinstalling them could be lots of headache, up to the point of reinstalling the the entire system. I will advise if you are not to good with computer, get a technician to do it for you. But if your are good enough, uninstall your current driver for the printer and look for any entry of it on the registry and delete it also search the installation folder and delete the folder. Restart your system and install the printer again.
Sep 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I have an HP 1410 PSC All in one It is supposed to have a Solution Center Icon on the desktop but it does not. Is the software improperly installed?
Yes it is.
I had the same problem with the 1300 series.
Uninstalling it from Add/Remove programs and then reinstalling it had the same problem. i had to uninstall it from the program directory, delete the program directory then do Add/remove programs and then reinstall it to get the Solution center and HP Director icons.
Dec 01, 2009 | Microsoft Windows XP Home Edition
5610 printing just a line in the middle of the page, else blank!
wow..I could be the FIRST..I am impressed..NOT!
check to see if there is ink, by blotting the print head on damp paper towel.
otherwise..delete and reinstall the printer. could be a software problem.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
How to uninstall the HP Solution Center & other software
Start - control panel - add and remove programs - DELETE PROGRAM
Mar 14, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
HP Solution center doesn't start...
I'll assume that you actually have an HP printer (or scanner) attached to this unit.
Uninstall the HP drivers and software which came with your HP printer (or HP scanner) and reinstall it from the driver discs (reinstalling the HP software over the existing installation may take care of it also). If you don't have the discs that came with your HP equipment please post what model you have and I will track down a link for you to download the necessary stuff for reinstall.
Feb 26, 2009 | Acer Aspire 5315 Notebook
In my laptop is HP PAVILION dv2000 model.
That 'beeping' is from the processor. The speakers aren't working because there is no sound driver installed.
Reinstalling the OS or initiating a system recovery will delete all the sound drivers (maybe others).
So, download your required drivers from here (search for your particular model in the series).
Nov 25, 2008 | HP Pavilion dv6000z Notebook
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Oct 20, 2008 | Office Equipment & Supplies
Ah ... HP software is the worst ... if you are using XP or Vista simply use the built in wizards to scan or print ... If you really need the print center first check in my computer ... c: drive: program files... HP folder ... if the software is corrupt you need to reinstall which is a leangthy process with HP.... the best bet is to use the HP scrubber tool ... then delete all hp printer folders ... then run a registry cleaner (ccleaner) ... then restart and reinstall ... before reinstalling use the msconfig utility to disable all of your startup items (not safe mode) then reinstall
Mar 29, 2008 | Dell A940 All-In-One InkJet Printer
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
