Question about Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart
AL2340 will not prime. Motor runs but cannot get it to prime
  • Anonymous Apr 26, 2009
    I had the same problem but this advice fixed it. The water worked like a charm! Thanks "PC_Tech50" !
    President:
  • Campbell Hau... Master
  • 1,388 Answers
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Posted on Dec 11, 2008
    Scholar:
    New Friend:
  • 49 Answers
I actually own one of those I use once in a great while mainly for my power roller which is maybe twice a year (maybe)
It's not really an "Airless" it is a diaphragm pump it runs constantly unlike an airless which is mainly a hydraulic pump which compresses the paint to whatever setting you have the pressure valve to, there are no check balls per say but the setting knob is held on by a set screw pop it off and look inside I think there is one plastic marble look for anything obvious like dried paint-
Posted on Jan 24, 2015
Recently purchased a goulds pump mod #c48a93a06. Lost power for about hour. Electric returned but water never came back on. Should I have to prime the pump again on a new unit?
See if the motor is running. You should be able to hear it. If it is then you need to check the prime. If it is a prime issue then the motor runs the risk of never shutting off and could overheat.
Nov 20, 2017 | Plumbing
Done every thing suggested. Still doenst prime. should I fill sand filter?
No prime = either impeller problem, air leak, or blockage on output(bad filter or bad valve) My first choice is dirty filter. Second choice is impeller. Both easy to check.
If you have checked those than you probably have an air leak. Hold a very slow running hose over all pipe joints running into filter, while motor is running. Most likely place is the screw in fitting on front of pump. The water from hose will temporarily seal leak and it should prime.
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
It just quict. if i prime motor it will run short...
if it has fuel pump unhook line from pump and gravity feed carburetor if it runs the pump is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart Logo
2,934 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
