Question about HP Pavilion dv6000z Notebook
Dont know where to hook up my keyboard to the laptop
Where is the port to connect my keyboard?
    President:
  • 2,110 Answers
You need a USB keyboard to connect to laptop...
oterwise if U have PS2 keyboard then u need to buy a ps2tousb adapter...
Posted on Dec 09, 2008
ONA11H0089
Did it ever work? Is the port it is connected to the correct port? Is the port active? Try a different port? If yes, try a different keyboard in the port. Does it work? If not, you may have a blown port.
Apr 02, 2014 | Computers & Internet
Keyboards doesn't work
sometime windows has some driver error or maybe your usb port or ps2 port for keyboard broken. If your keyboard connect into usb port, please Try into other usb port.
this is because of broken keyboard or broken port. Try using a new keyboard or good keyboard to see the diffrent.
By the way here the other solution link..
Laptop Keyboard Not Working Here What To Do
thanks
Jan 20, 2014 | Computers & Internet
Keyboard failure on dell dimension 2400
Your keyboard needs to be pluged into one of either a USB port, if it has a USB connection or a PS2 Port if it has a PS2 connection.
USB is the rectangular shaped port, while the PS2 is a round, usually purple coloured connector.
Try pluging it in and out, with USB connection type try another USB port at the rear of the chassis or on the front too.
It is possible that the keyboard is faulty, in other words it has come to the end of it's life. Meaning that you may need another keyboard.
Try this keyboard on another computer, a friends computer will do. You could even try a friends keyboard in this computer as another test.
Take care!
damnor01
Jul 04, 2011 | Dell Dimension 2400 PC Desktop
KEYBOARD WON'T CONNECT TO PC USB PORT, TRIED 3 DIFFERENT KEYBOARDS. MOUSE CONNECTS FINE
Will the keyboard connect to the port you have the mouse in? The only thing I can think of is that there are bent pins in the USB port on the machine. If it has more than one USB port try another one. If all else fails you can always get a USB hub.
Oct 29, 2010 | Dell OPTIPLEX 745 PC Desktop
The number keys won't work, the ones located on the far right of the keyboard/calculator area....
  • Disconnect and reconnect your keyboard if it is external. Make sure that the connector is completely inserted into the port. (USB plugs fit into ports one way only, and won't allow you to make a connection if you try to connect them in upside-down.) Test the keyboard again.
  • Connect your keyboard to a different USB port.
  • Try a different keyboard on your computer if possible
If same problem occur even though the keyboard is connected in a different computer, then you need to contact a local repair tech and have it repaired.
Thank you!
Feb 08, 2010 | Dell 0Y3740 Keyboard
NEW KEYBOARD NO MICE
No.
Usually, a mouse connects _directly_ to either the 'PS/2' mouse-port on the computer, or connects to a USB-port on the computer.
Some keyboards have a USB-slot, to allow a USB-port mouse to be connected.
Nov 13, 2009 | Computers & Internet
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
Did you figure out your KVM?
if you tried to connect your mouse to the keyboard port and still it doesn't work. Power cycle meaning unplug the KVM from the CPU, monitor, keyboard and mouse. Then wait for about 30seconds before reconnecting again. If you still encounter the same problem that the keyboard port won't work then it means that keyboard port is defective. Replace it.
Jul 27, 2008 | IOGear GCS632U 2-port KVM Switch
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
