Question about HP (153147-001) Sound Card
Lost sound (no changes to computer)
My hp lost its sound all of a sudden. sound control still on my control panel
    Master:
  • 461 Answers
Check the speaker connection - should be plugged into the green jack on back of PC. Do your speakers have a power light to indicate they are on? Check power cable.
Posted on Dec 09, 2008
I have an HP w19b monitor & all of a sudden an audio box appeared in the middle of the screen & I can't get rid of it!
sounds like virus infection to me
scan it for virus, full,
and run , malwarebyte, free.
Mar 09, 2017 | HP Computers & Internet
HP LAPTOP SUDDENLY NO SOUND
Go to Control Panel, Hardware and Sound, Sound, Manage Audio Devices - check that you indeed have an audio device installed (sometimes they disappear!). If not, go to HP.com and go to Support. Enter the information for your computer to find the device driver for YOUR computer and OS (operating system) and download and reinstall the proper driver to hopefully solve the situation.
Feb 20, 2015 | HP Computers & Internet
Sound lost from my laptop model compaq presario c300
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps
Jun 18, 2012 | HP 435768-001 - Compaq Presario C300...
I have checked and the speakers are working however I suddenly lost all sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell Computers & Internet
Why did I suddenly lost sound on youtube videos and what should I do to have sound again? I have Windows 7. Thanks Rita
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 03, 2011 | Computers & Internet
I have HP laptop and i suddenly lost sound, i cant hear anything. i want the solution
Click start > Settings > Control Panel > Sounds and Audio Devices. Make sure it is not muted and volume is on high.
Click audio tab and under Default device is it set to SoundMAX HD Audio? if this device is not available try another device and click Apply and test. (you may need to close windows media player or whatever is playing the sound and reopen after changing default device)
Aug 23, 2010 | HP Pavilion DV6700T Notebook
I have lost sound on my Dell XPS M2010
Yep - this I run into every start up, or every awake session from Standby - the problem is that the default sound device changes - I've gone through the control panel, and put a shortcut to the Sound mechanism in my taskbar - then when it changes, I just modify back to the Speakers/Headphones setting - I usually have to change stations on Pandora, or skip to a new Youtube, but it all works our very quickly.
May 29, 2009 | Dell XPS M2010 Wireless Bluetooth Keyboard
Lost sound
fist of all check any extrnal speakers with your pc or
1. Check all your connections and make sure you have them in the correct places and connected completely.
2. Check your sound settings on your computer. Go to Start, Control Panel, Sound and Audio Devices and see if it is turned up or if it is muted.
3. With the above it will be able to tell you if the driver is missing. If so go to the HP website and get the Audio Drivers for your computer. Install thoses and restart your PC and go through steps 1,2 again if there is no sound. Now if that fails you may have bad speakers.
Apr 24, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Pc speaker
You go through control panel option sounds & audio device there you will get enable speaker option check that one.
Feb 13, 2008 | HP Compaq Presario V2000 Notebook
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Koala babe, narrow the problem. Is there any sign of power presence in the unit. Could be just a power issue. You did not mention any lights indication on your front panel.
Good luck.
Jan 22, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
HP (153147-001) Sound Card Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
