Question about Lasko Ceramic Heater
Lasko heater run about 5 minutes and shut down/how to clean
The heater is two years old and I think it needs cleaning, it runs about 5 minutes and shut down and you have to wait about 5 more minutes to start it again and it will run about 5 more minutes my email address is trainmanw@email.com
  • Anonymous Dec 22, 2008
    I have the same problem....for awhile cleaning the vents on the back worked but now it's to the point where that no longer does the trick. I myself am trying to figure out how to open the heater up to clean it further
  • dado255 Nov 14, 2009
    There is a recall on the heater's control modual... It must be sent in or replaced. Lasco offers a free replacement, if the product code and other information from your reciept is given to them. As well,.. if you purchased a Product Care Plan from Wal Mart ,you may replace it with a simular heater
    Problem Solver:
  • 8 Answers
I have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
  • 2010an28 Nov 04, 2010
    thanks Karnenote, it worked.
I HAD THE SAME PROBLEM TOOK IT APART CLEAN IT OUT FROM DUST WORKS GREAT
Posted on Mar 27, 2010
I just took the heater apart like Karnenorte mentioned and there was a lot of dust caped up on the coils!! Put it back together and it is running great!
Posted on Dec 20, 2009
  • 10 Answers
IT IS NOT NOT THE THERMOSTAT
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Posted on Oct 16, 2009
    Genius:
  • 1,199 Answers
Sounds like the thermastat has burned out (telling it to shut off)!
Posted on Dec 09, 2008
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
My little heater keeps shutting off after a couple of minutes. I tried resetting it, and that gets it running again....for a couple of minutes.
The cleaning suggestion worked well. I cleaned mine with a blower nozzle on my air compressor. After blowing out all the dust and dirt from the front to the wind turbine out the sides. I saw a cloud of dust blow out of mine until it stopped blowing out dust. After that it seems to not be shutting off anymore. So Im thinking next time i won't take it apart just try using the compressor blower attachment again. Thinking ill get the same result. Also i changed the screws to a standard Philips head so disassembley in the future will be easier. Some of the torques screws had the stopper in the center of the screw that had to be drilled out. Must be a stopper for people that like to repair things themselves.
Feb 04, 2011 | Lasko 675900 Stanley® Heater
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Dec 28, 2009 | Lasko 5530 Ceramic Compact Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Lasko heater shut down
Feb 15, 2009 | Lasko Ceramic Heater
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Lasko  Ceramic Heater Logo
1,263 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
