Question about Kenwood Car Audio & Video
DNX7120 is a nav and tuner unit as well as sirius moduals. the first issue how do I keep fm music as background to the GPS display is active and on screen.
  • 1,800 Answers
Press the button beside "KENWOOD".
and a menu will appeared :
DNX7120 is a nav and - 5a0f3db.jpg now select the source like Tuner un this case -the fm station shud already choosen.
plz do rate this post
Posted on Dec 09, 2008
  • 4,472 Answers
Http://www.bzcaraudio.com/files/dnx7120.pdf
follow this link to download your manual. You will need adobe acrobat to read it which you should have. On p. 14 is the exact steps on how to play another source while using the NAV. if you have any other questions please let me know. Also please take a moment to accept and rate my solution.
Thank you,
Lee
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
Can i play mp3
Yes it does.....I have included a full list of specs for you for this model
  • DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
  • fits double-sized (4" tall) dash openings
  • motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
  • plays CDs, CD-Rs, CD-RWs, DVDs, DVD-R/RWs, and MP3 discs
  • GPS navigation (includes GPS antenna and map DVD-ROM)
  • City View mode - 3-D maps that render accurate representations of specific buildings in many cities
  • 6 million points of interest (hotels, restaurants, gas stations, etc.)
  • customizable route preferences
  • separate CD and DVD slots
  • five soundfields: cathedral, club, concert, live, theater
  • 9-band parametric EQ
  • 5 preset EQ curves
  • SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
  • compatible with Eclipse HD Radio™ tuner
  • CD changer controls
  • audio/video input
  • rear-view camera input
  • audio/video output
  • 5-volt front, rear, and subwoofer preamp outputs
  • AM/FM tuner
  • 6 FM/6 AM presets
  • warranty: 1 year
Oct 08, 2010 | Eclipse AVN5500 Car DVD Player
07 jeep compass, am/fm/cd works fine, built in sirius keeps flashing 184.. whats going on, and what can i do to fix it?
It's a bad Tuner. If the vehicle is still under warranty, get it replaced. If not, call the dealer for the replacement part cost. It may be worth it to just replace the entire unit with an aftermarket unit. Very common problem until late 2008. Hope this helps
Oct 12, 2009 | Sirius Satellite Radio Receiver
Pioneer AVIC 700 sirius satellite radio stopped working, stuck on
My AVIC-F900BT was stuck on one channel and wouldn't change. There was no sound. Radio head detected Satelitte system, but no buttons worked. Found on the internet a solution that worked for me. I disconnnect the battery terminals for 5 minutes and then connected them. When the system rebooted, the Sirius radio worked fine. I'm posting this hopeing it will help someone.
Oct 03, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
Nov 25, 2008 | Sirius Satellite Radio Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Jensen MSR4050G Sirius Ready marine radio
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
May 19, 2008 | Jensen MSR4050G CD Player
Dodge RB4 GPS system
Sounds like the J1850 bus is not connected to the RB4 radio.The speed sensor info is received thru the bus which alows the nav to function and calibrate itself.Or as I have mentioned before, there may be problems on the NAV pcb.There have been many issues with the nav pcb assy.
Jun 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Car Audio & Video Logo
20 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
