Question about Panasonic Televison & Video
Tv wont turn on
Tv starts to turn clicks like everything ok then after a couple seconds,it turns off and power led blinks 12 picure or sound.
  • Anonymous Jan 01, 2009
    mine has the same problem but blinks 7times
  • 152 Answers
hello, usually if your panny is blinking it means theres trouble with your power supply but depending on the number of blinks cuased by a fualty or shorted internal board and this will cuase your tv to go into shutdown mode, it depends on your model number and year it was made.
your best bet is to have a qualified service tech give you a estimate for the repair needed. as long as your screen is okay it will be easy for the service tech to locate and fix your trouble
panasonic blinking codes can pin point the troubled internal part, these blinking fualts are cuase by internal boards with malfunctioning circuts info below for 10th gen 2007 2008 plasma model service
12 Blinks SOS:
On the A board, transistor Q2301 monitors the Sound 15V line and the operation of the audio power amplifier IC2301. If the audio output circuit, IC2301, or the 15V lines develops a short to ground, transistor Q2301 goes into conduction and applies a high to pin 118 of the MPU, IC1100, triggering a SOS condition. The power LED blinks 12 times.
12 Blinks SOS: We have also discovered that 12 blinks of the power LED may also be caused by a defective SS board. To determine the source of the shutdown, disconnect the connector D5 and connect the unit to the AC source. If the panel turns on and the LEDs of the SS and SC boards stay on, the problem is on the A board. If the panel does not stay on, the problem is likely to be the SS board.
hope this helps
Posted on Dec 09, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
Sep 26, 2014 - Uploaded by
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
Jul 24, 2011 | Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like, to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Tv shuts off and led power light blinks
Turn off/on couples times,power it well come back on stable,if not ur video board it dead.
Dec 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Televison & Video Logo
653 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
