Question about Alfa CM-110 Coffee Maker
CofferMaker won't brew coffee properly
I have a Alfa cm-110, and it will brew initially, but won't brew throughly or keep water hot. I am member of group, and I have to make coffee for at least thirty people a week. I usually put in enough water and coffee to produce 2/3 the capacity of the maker. The maker half works. It is difinitely making some members unhappy. Can it be fixed and if so, where?
  • John Zeigler Mar 01, 2007
    Would anyone know how I might be able to contact the manufacture?
  • 72 Answers
Sounds like maybe the temperature sensor is cutting it off too early. This is an expensive ($200 US) pot so I would contact the mfr. They might have a quick solution.
Posted on Feb 25, 2007
SOURCE:
Water puring out underneath Gaggenau coffee machine
The water in unit is fed via a hose to the heating element. If the hose is broken or disconnected the water never reaches the element and spills out the bottom nice and cold.
If you remove the bottom panel the problem will be instantly obvious.
OR put water in unit and see where it comes out of!!!!!!!!!
Aug 30, 2015 | Gaggenau CM 200-630 Aluminum Espresso...
Won t brew coffee just hot water
First try using a paper clip or long pin to clean the 2 tiny holes in the upper prong that pokes thro the top of the coffee cartage. I had the same problem and that fixed mine
Feb 17, 2015 | Keurig Elite B40 Coffee Maker
Bloomfield coffee maker won't brew hot water
Do you mean the machine will not heat up?
Oct 18, 2012 | Bloomfield 8572 Coffee Maker
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
I need a glass gauge( two) plz give me a call
Does anybody know where i can get the glass gauge for a alfa coffeemaker cm-110?
Dec 28, 2010 | Alfa CM-110 Coffee Maker
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Alfa CM-110 Coffee Maker Logo
114 people viewed this question
Top Alfa Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you an Alfa Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
