Question about Dewalt D28494N 7" and larger Electric angle grinders
Grinder problems Hi i have a d28494 6000rpm dewalt grinder. it will not do anything when i plug it in. if you could give me any advice that would be great thanks Dusty
  • TechTrainer May 11, 2010
    do you feel comfortable enough to take the handle apart?
  • 211 Answers
Hi
Check the power suply cord, the switch ONN/OFF ;the brushes and the electric engine(field and armature).
best regards savumihai71
Posted on Dec 11, 2008
Fixing bad motors in dewalt angle grinders power tools
it would be much better if you bought a new one because it would be cheaper
Jul 04, 2014 | Dewalt DW824 5" Electric Angle Grinder
Grinder does not go up to speed when turned on
Maybe wrong color wires used connecting over the (capacitor)start winding giving a wrong rpm, or just only a worn stator coil.
Aug 26, 2013 | Dewalt DW758 Power Grinder
Why is my dewalt grinder extremely noisy
lite grease is washed out to the edg of gear box, just give it a mix so gears get the lub again, good look
Apr 11, 2012 | Saws
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    The Dewalt DW888 Die Grinder does not come with a guard. Is is permissable to operate it without one?
    on a die grinder like this one yes you can, make sure that you do wear safety glasses though
    Jan 18, 2011 | Dewalt DW888 Die Grinder
    Dewalt 4 1/2 angle grinder
    A Dewalt 4-1/2 inch hand grinder that normally uses 110-120 volts? Probably fried the armature windings.
    Check the switch (Out of grinder), and see if it has continuity. (OHMS test with multimeter) Pretty rare thing, but perhaps the switch took the brunt of the overload. If this is the case replace the switch.
    (After checking continuity on armature, and field windings, of course. If either one is bad, a new switch won't help)
    Which Model Number is it, and perhaps I can find an exploded drawing for you.
    Nov 13, 2009 | Saws
    Sparking bruch
    most likely the carbon brush is worn out and need to be replaced.
    Jan 15, 2009 | Dewalt D28494N 7" and larger Electric...
    Dewalt D28494N 7" and larger Electric angle grinders Logo
    214 people viewed this question
    Top Dewalt Saws Experts
    JOHN LAPIER
    Craig Butler
    Craig Butler
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
