Mitsubishi VS-60707 60 in. Rear Projection Television
Problem for Mitsubishi VS-60707 60 in. Rear Projection Television
Tv not coming on
By m_okeefe on Dec 09, 2008
%0 inch rear projection Mitsubishi. When I turn ot on by remote or by main power button it turns on and off immediately on it's own. I have tried to unplug to reset with no luck. Any suggestions.
Comments:
Dec 09, 2008
- I tried to remove the batteries from both the TV remote and the master satellite remote. Still the same problem. It just clicks on and right back off from the main power button on the TV. Any other suggestions or is it time fro the repairman - or the junkyard?
Same Problem
Apr 10, 2009
-   tv wont come on led light just blinks thats it-   Guest
Jan 04, 2009
-   tv wont come on -   Guest
Dec 31, 2008
-   inch rear projection Mitsubishi. When I turn ot on by remote or by main power button it turns on and off immediately on it's own. I have tried to unplug to reset with no luck. Any suggestions -   Guest
Solution #1
posted on Dec 09, 2008
Somewhat Helpful)
Opelmanz
Rank: Wiz
Rating: 78%, 35 votes
try removing batteries from all remotes, a faulty remote may be turning your TV on/off. If it still does this, there is a power problem and you likely need a tech to look at it.
Comments:
Dec 09, 2008
- if the repairman can fix the TV for half the cost of a new one I say fix it, otherwise time to save for a new TV.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-60707 60 in.
Questions and Unsolved Problems for Mitsubishi VS-60707 60 in.
Do you recommend Mitsubishi VS-60707 60 in. Rear Projection Television?
Answer
Answer
my tv does not want to power on but green timer light blinks on
Answer
t.v. will not stay on. when i turn it on i hear a double clicking noise and the power light flashes... (More)
Answer
i have a 60" mitsubishi projection tv model vs-60707.turns on and plays fine for awhile then... (More)
Answer
I have a vs 60607 tv / input menu code is 1 2 lights come on for 1 sec then dim good audio
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi VS-60707 60 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
