Sony STR DE635. I can unplug stereo for 30 minutes, restart and rears will work. I checked all wires going into stereo, twisted and cut clean and re inserted. Had cabinet door open this time with fan blowing on stereo same thing. Also took receiver apart and vacuumed dust balls.
Temporary Fix. My rear speakers cut out as well so to fix it temporarily I switch the receiver to "Test Tone" Mode and crank it up a bit until the test tone (white noise) turns the rear speakers on. Turn down the volume first then turn off the "Test Tone" Mode. HTH
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
HI! got the same problem, something wrong with the relay i think, or somting thats controls the relay. If i can reatch i'm gong to re soldering the relay and se if thats the problem. its place is bad compaird to the other relays=/ anyway have you got any solution for yours yet?
