Question about Amana Heating & Cooling
Have amana ptac heat will not turn off,hear clicking sound
  • 1,800 Answers
  1. Thermostat is set on Heat and turned on. Next if electronic, are batteries charged? Is there a display showing? Set temperature three degrees or higher than current room setting.
  2. Power supply. Your furnace should have an Emergency Power Off Switch. Make sure it’s on. Next check main breaker box. If a breaker is tripped it will be between ON and OFF. Reset the breaker by turning OFF, then back ON.
  3. If you have fuses, check to see if the fuse for the furnace is blown. If so, replace it with the SAME SIZE fuse. Do not increase the size of the fuse. WARNING: If a breaker is tripping or a fuse blowing more than once, call a qualified technician to inspect your system to diagnose why you are having problems.
  4. Dirty air filter can cost you more than you think. It also can cause no heat. Clean or replace filter. All air filters have a certain amount of airflow resistance. Add dust building up on the filter and eventually it begins to block airflow and requires more energy to operate. Reduced air flow also stresses other components that can be costly to repair.
  5. Fuel supply – make sure you have oil or gas supply and that valve is open.
  6. Blower motor needs to be reset (due to an overload). RESET button should be near the blower motor's housing - press it. If motor does not respond, wait 30 minutes for the motor to cool, then try the RESET button again.
  7. Pilot light could be out. Newer furnaces will have intermittent pilot, hot surface ignition or direct spark. If your furnace is older you probably have a continuous burning standing pilot that is used to light the main burner. If your standing pilot won't stay lit, try replacing the thermocouple. If that still won't work try another thermocouple then replace the gas valve (sorry not much else can be done)
plz rate this post
Posted on Dec 09, 2008
  • Jalal Sordo
    Jalal Sordo Dec 09, 2008
    sorry i ment OFF
    Genius:
  • 1,199 Answers
Thermastat sound broken !
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Jan 02, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have an Amana PTAC that was just installed two weeks ago. I am starting hear a moderately loud warbling sound when it is in operation but not all the time. It's loud enough to wake me up in the next...
Is is the sound of water being thrown around? Some units actually sling the water from the drain pan back onto the coil. This improves efficiency. It's sort of a gurgling sound. Here's more helpful information is you need it:
<a href="http://www.ultimateptac.com/ptac-faqs/">PTAC FAQs</a>
Dec 19, 2010 | Heating & Cooling
Amana PTAC ''Auto'' setting doesn't work. I turned on ''Heat'' and then ''Cool''. I can get the ''Low'' and ''High'' settings but not the ''Auto'' Please help
sounds like ur board is gone out and needs replacing if u dont no about these units i dont advise trying to do this trust me save urself some money and headach and call a tech
Feb 23, 2010 | Amana PTC093B50AJ Electric Heat Air...
Ptac not heating
the board or the heater need to be replaced
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
119 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
