Question about LG Washing Machines
LG direct drive 7.5kg wd14750sd will not wash. displaying "de" error...
SOURCE: error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Posted on Oct 10, 2008
  • 489 Answers
SOURCE: de is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Posted on Apr 28, 2008
Controlfrk
  • 304 Answers
SOURCE: keep getting de error code display for LG WM0642H
Call for warranty service should be in warranty for a year.
Posted on Aug 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
Jahn27
  • 1554 Answers
SOURCE: looking for manual for LG
Here's the User's Manual for your LG WD-14750SD Washing Machine.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting the solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding your concern stated herein.
Posted on Sep 06, 2010
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
Hello: I have an LG front load Washer Model #WM2010C. Its' receiving a error code (de). I've looked it up and it seems to be "door error." I cannot open the door. When I go to...
You will need a new door llock switch.
to change it you will need to loosen the front bellow by removing clamp, unscrew the twwo scrwes holding the switch then unplug wires to switch and re-install.
Jul 02, 2011 | Washing Machines
LG Top Load Washing Machine Model: WF-T7517TE , kg TURBO DELUXE. On Pushing START button , MAchine just starts and stops after a second. Message displays "dE". What to do ?
'de' on LG's stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 20, 2011 | LG Washing Machines
LG inverter Direct Drive 7kg WD11020D - what is "ue"?
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
Mar 06, 2011 | LG Washing Machines
LG direct drive system is coming up on the display screen - de. What does this mean please?
The DE code indicates a problem with the door locking and can be the control, door latch or door switch assembly.
The first image will help with this.
If you feel comfortable with your do-it-yourself abilities then the 2nd image will be useful to you.
Jan 10, 2011 | LG Washing Machines
DE door switch problem
I bought a switch in Portugal by €7,5 and ...nothing. I bought a drain pump €18 and still not working. I have consult one tecnical expert by phone were i bought the pices and he said tha could be the pwc board (€75). Here in Portugal they quote €25 to come and €30 per first hour...I decided and I bought a new Lg with direct drive but I stored the old Lg (6 years old, without problems, and working 2 times per week)...if you try... and it works tell me ok ? Good Luck.
Oct 07, 2008 | LG WM-1832C Front Load Washer
De is displayed when i turn machine on
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
Error code DE means door error problem.  Could be that the door switch doesn't sense the locking mechanism is working properly and may need to be replaced.  This will require a service call from a qualified LG tech to diagnose the problem.
Jan 04, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
343 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
