Hoover 500M washer timer stops mid cycle - looks like i need whol
Control panel. is this right? rough price? grateful for answer - i don't want to get service out here in the bush, only to find a new machine is a better choice.
SOURCE: 2nd Bosch washing machine same problem
put tester on drain pump power wires and see if power is there. if so,your pump or the line is blocked.
Posted on Oct 11, 2007
SOURCE: need to remove agitator on
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Posted on Mar 12, 2008
  • 38 Answers
SOURCE: hoover 500m spin cycle
That sounds like a broken motor couplin, slack drive belt, or worn bearings.
A repair person can determine which is it. I cant tell from here. However,
If you do this test you can eliminate one of the above. Lift the lid of the washer, hold the rim of the inner-tub and spin it clockwise and then anti-clockwise. If it spins both ways, you have a bad bearing which needs replacing.
Posted on Jun 01, 2008
  • 278 Answers
SOURCE: My whirlpool duet washer has stopped mid cycle and
Sounds like the timmer in the control module has frozen and will not advance. It's one module for the whole display. I sometimes tap the module with a plastic screwdriver witch may releace it but it will do it again. I sorry to say but it's time for a repair man. I do't have the writing space to tell the procedure (if it is the problem) - Sorry, not good news
Posted on Oct 16, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
My Hoover UltraCare 1500 washing machine keeps repeating the spin cycle, even when I turn the programme control knob to stop
Sounds like the timer control switch is messed up. I had the same thing happen to my washer because my roommate was impatient and tried to spin the timer like the big wheel on the Price is Right. The plastic tabs broke and the timer died.
Jan 28, 2015 | Hoover Washing Machines
Whirlpool 1000 w100 stops after filling with water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 30, 2012 | Creda W100FW Front Load Washer
Agitator continuously on
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
see the diagram
Sep 30, 2012 | Frigidaire GLWS1233A Top Load Washer
Washer stops at rinse cycle and give the ul code F1
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Washer Stops Mid-cycle
HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
Replace this damaged timer control device asap.
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer stops in mid cycle
check the connection at the main control board top right side just remove the top
Nov 29, 2008 | Washing Machines
My 5 year old Hoover 500 mb has started to stop mid cycle or not progress through the cycle !
Mate, I just had the same fault with the same model machine. The local machine repair man called me (i'm a sparky) to double check things for him. The macine stopped at the pre wash rinse part of the cycle every load. He replaced the timer with two NEW ones which both had the same fault as the original. We now suspect an inherrent fault in the timer design but as yet dont have an answer.
Aug 10, 2008 | Hoover Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
