Question about Compaq Presario 5000 PC Desktop
Missing shell32 I am trying to casinos online.I was told to install active x i get message missing export32.dll.get folder path a I am lost I have windows 98 se compaq pesario model 7594
  • 837 Answers
More than likely you have an issue with windows 98 ...
Posted on Dec 09, 2008
How to install the SHELL32.DLL
which operating system ??
Older version of the Windows operating system, such as Windows 98 and Windows XP, allowed the user to change whatever they wanted within the operating system files, with little or no protections or oversight.
That all changed on Windows 7, however, and you are now prevented from making most modifications to operating system files such as shell32.dll.
Modifying and moving these files can be extremely useful at times, however.
You should be aware, though, that modifying and moving files such as shell32.dll may impair or break your operating system in some way.
Open the start menu by clicking on the Windows icon in the lower left corner of your desktop. Click on "All Programs," then on "Accessories" and finally on "Command Prompt," which will open up the Command Prompt program.
Type "cd C:/Windows/System32" in to the command prompt and push the "Enter" key.
If you have installed Windows on a drive other than C you will need to replace the "C" in the above command with the correct drive letter.
Type "TAKEOWN /f shell32.dll" in to the command prompt. Push the "Enter" key.
This gives you ownership of the shell32.dll file.
Type "ICACLS shell32.dll /grant USERNAME:F" in to the command prompt and push the "Enter" key.
You will need to replace "USERNAME" in the command with your username.
This is the name that you see when you log in after turning your computer on.
Rename shell32.dll to something else if you are planning to copy a new shell32.dll in to the System32.
Do this by typing "rename shell32.dll shell32.dll.backup" in to the command prompt and pushing the "Enter" key.
This will rename the old shell32.dll to "shell32.dll.backpup" so that if you ever need to revert back to it, it's available.
Alternatively, you can use File Explorer to navigate to the System32 folder and change the name like you would any other file.
Type "copy path\to\modified\shell32.dll C:\Windows\System32\" into the command prompt and push the "Enter" key.
You will need to replace the "path\to\modified\" portion of the command with the file location of the new shell32.dll that you're copying in to System32.
Alternatively, you can use File Explorer to copy and paste the file as you normally would.
Replace shell32-dll windows 7
http://windows7themes.net/how-to-replace-shell32-dll.html
Jan 14, 2012 | Compaq Computers & Internet
My computer wont start says is missing shell32.dll says i have to reinstall this program
Causes of the error:
Shell32 Dll Problems are caused by misconfigured system files.
Shell32 Dll Problems usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Shell32 Dll Problems are easy to repair. By downloading and running the registry repair tool WiseFixer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your download. To Fix the problem you need to follow the 3 steps : Step 1:
Download & Install WiseFixer. Note:If the download link doesn't work you may need to Download it from a mirror Here
Step 2:
Click the "Quick Scan" button.
Step 3:
Click the 'Repair All' Button to Repair Your PC!
Dec 09, 2011 | HP Computers & Internet
I can't change my background
Hi
Download shell32.dll from the following link, and then type "regsvr32 shell32.dll and press Enter" at Run Command in Windows 7.
When you click the following link a page will open, Click Download shell32.dll to download the file.
http://www.dll-download-system.com/dlls-s-/shell32.dll.html
If you face any issue, please let me know.
This solution is absolutely FREE, please rate and give your feedback.
May 10, 2010 | ASUS P5PE-VM Motherboard
Installing windows 2003 server on IBM bladecentre HS20. Gone through the preliminary installation configurations using the blade's setup steps. Prompted to remove disk after setup has completed copying...
shell32.dll file is very important windows system files.It control all users grapgical settings, icons, anything related to graphic user interface of the Operating system.If shell32.dll cannot be copied during installation,the system never gets to GUI mode.Try using a New CD/DVD.it will solve your problem.
Oct 14, 2009 | IBM eServer BladeCenter HS20
Folder Option
show Hidden Files option is missing from folder option...
In windows explorer, when i go to "Tools" , "Folder Option" and click on the Tab "View" and under the "Hidden Files and Folders" it only shows "Do not show hidden files and folder" . The option for Show hidden files is missing
Before the fix
This is caused by viruses ...
To fix this issue follow below steps..
1) open notepad.
2) copy below text and paste in notepad.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden]
"Text"="@shell32.dll,-30499"
"Type"="group"
"Bitmap"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,53,00,\
48,00,45,00,4c,00,4c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,34,00,00,\
00
"HelpID"="shell.hlp#51131"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN]
"RegPath"="Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Advanced"
"Text"="@shell32.dll,-30501"
"Type"="radio"
"CheckedValue"=dword:00000002
"ValueName"="Hidden"
"DefaultValue"=dword:00000002
"HKeyRoot"=dword:80000001
"HelpID"="shell.hlp#51104"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL]
"Text"="@shell32.dll,-30500"
"Type"="radio"
"CheckedValue"=dword:00000001
"HelpID"="shell.hlp#51105"
3) Save as fix.reg ( make sure to give the extention as fix.reg
4) Double click on this file and click yes when prompted.
5) Issue is fixed now. see the prof below.
-- Let me know if still issues, will glad to help you.
Thanks.
Subhash Chandra.
Jul 08, 2009 | Acer Aspire One PC Notebook
Missing shell32.dll file
Go to your bios and make the cd rom the first boot disk.
To get into the bios, usually del key when booting gets you in.
Once you boot from the xp disk, follow the prompts until you get to the screen to hit f8, on the next screen hit R and the system will do a repair with out changing any of your settings.
Be sure to go to Microsoft and run the XP updates.
Mar 13, 2009 | HP Compaq nx6110 PC Laptop
I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
HKEY_CLASSES_ROOT\Directory\shell
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
My Book (G:) icon is different
no you there iss no big problem.
The icon of your hdd iss created from the autorun.inf
http://www.fiveanddime.net/notes/hd-icons.html
Change hard drive icons Change hard drive icons:
To change the icon for your hard drive, create the
following file in notepad:
[autorun]
icon=C:\WINDOWS\SYSTEM\Pifmgr.dll,36
Notice it's two lines.
If your hard drive is C:
click Save As... and navigate to C:
and save it as autorun.inf
enclose it in quotes so Notepad won't put a .txt
on the end of it
The path specified is the typical Windows path
yours may vary, but you'll have that dll file.
The 36 at the end is the number of the icon I chose.
(Icons in a file are numbered, starting at 0.)
To see the change, open Windows Explorer; click
F5 if needed to refresh.
To preview your icon options, select an icon on
your desktop, right-click and select
Properties, then Change Icon. You can also select
any other .dll file in your computer, although most
won't have icons.
The common Windows icons are in
C:\Windows\System\shell32.dll
(xp = C:\Windows\System32\shell32.dll)
You can also point to a single icon.
Using the example above:
[autorun]
icon=c:\windows\cursors\myicon.ico
I have three hard drives and nine partitions; under
WinMe, I had to move the icon/dll to each
partition and edit the autorun.ini, i.e.
C:\Windows\System\Pifmgr.dll,32 became Pifmgr.dll,32.
WinMe also wouldn't let me change the icons
for the primary partitions of the first two
drives, but did let me change the
primary partition icon of the third drive.
Jan 02, 2009 | Western Digital My Book Essential Edition...
Shell32.dll
Try running RUN and type regsvr32.exe /i shell32.dll.
This actually fixes the shell32.dll and installs it again.
RegSvr32.exe has the following command-line options:
Regsvr32 [/u] [/n] [/i[:cmdline]] dllname
/u - Unregister server
/i - Call DllInstall passing it optional [cmdline] (/i /u calls dll uninstall)
/n - do not call DllRegisterServer (must be used with /i)
/s  Silent (added with Windows XP and Windows Vista)
Aug 20, 2008 | Microsoft Windows 98 for PC
Compaq Presario 5000 PC Desktop Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
