Question about M-Audio Propellerhead ReCycle 2.1 (us920091) for PC, Mac
Recycle 2.1 crashes.... alot.
When i run propellerhead's recycle 2.1 it loads the desired sound file, give me access to the loop controls, and will even play a few measures (if i press the play button). but any time i play a loop long enough to edit it, the program crashes. i've uninstalled and reinstalled, and it hasn't fixed the problem.  also, i don't think it's a resources issue. i have a macbook pro, 2.5ghz intel, 4gb ram, and a 512mb nvidia geforce 8600 video card.
  • 1 more comment
  • Anonymous Jan 11, 2009
    same thing
  • Anonymous Apr 28, 2009
    same problem, i have it on a macbook pro
  • Anonymous May 12, 2009
    same problem here...I can change a wave file to rex2 file once but if I want to do it again with another wave file it crashes. Did not have the problem when I used a PC
3 Suggested Answers
SOURCE: I'm trying to open sound
Got the same problem dude.. is yours a cracked version by any chance? also i dont have a problem loading wav. files from a cd/album. Just Mp3 conversions that I have downloaded from youtube, then converted to wav. Please help as i need to use this software urgent! cheers.
Posted on Feb 26, 2011
SOURCE: Project Mix was running fine
It's quite possible that you need to repair the disk permissions on your Mac. Below is a detailed list of steps you'll need to take to repair the disk permission. Please follow the steps thoroughly. It is also important to note that you MUST be logged onto your computer as an administrator in order to troubleshoot this issue. First, you need to uninstall Project Mix completely. You may wish to try running the installation program again to see if an uninstall option is available at any point during installation to make sure that Project Mix is completely uninstalled. After uninstalling, Go to HD > Applications > Utilities > Disk Utilities. Specify your HD and do a Repair Disk Permissions. Reboot the computer once done. After reboot, Try installing Project Mix again and see if it will work.
If these steps fails to correct your "kext error" as we call it, then you might need to contact your software manufacturer for an updated driver.
Hoepe this helps
Posted on Apr 23, 2011
I use Mac I'm a new user of recycle when I try to make a loop i click on the left..set it..click on the right and set it when I press play it plays but won't stop and then I have to force quit
do u have the autoloop turned on and im not sure what you doing w loops and reason loops can only be used in 2 things in reason dr rex and the other sampler. my suggestion is if you new watch youtube videos, get on there site use the forums learn from others. also if you new to reason www.boyinaband.com makes some pretty sweet tutorials for you to follow along with. I hope this helps but if not it will get you in the right direction.
May 28, 2011 | Propellerhead ReCycle 2.1 (7350002920091)
Is propeller head recycle 2.1 compatible with vista and is yes why do I get error messages once it's installed and read to go.
yes, it is compatible. have you moved the .exe file? if so, this is your problem. it will not run if you moved it. before running the patch, it'd be better to put the .exe into your recycle folder.
for more, see http://www.propellerheads.se/support_area/index.cfm?fuseaction=get_article&article=winx64recyclepatch
Feb 28, 2011 | Computers & Internet
I'm trying to open sound loops and aif/wav files etc. but recycle says could not load *file*, the file is in an unkown format or corrupt. These files are fine because I use them through ableton ?
Nov 11, 2010 | M-Audio Propellerhead ReCycle 2.1...
I lost my original cd
Go to the Prop Shop at propellerhead.se. Provide your proof of ownership and order a replacement disc. $25
Apr 15, 2010 | Propellerhead ReCycle 2.1 (7350002920091)
ReCycle... with virus?
Instalad este parche los que tengais el SP3 instalado y procesador AMD y todo volverá a la normalidad.
Saludos
Jul 04, 2008 | Propellerhead ReCycle 2.1 (7350002920091)
Recycle cannot run because of an unexpected error
Dear Sir,
This is the trojan virus. call a computer expert immediately and get the windows reloaded, before your pc crashes completely.
Thanks
Good luck
“Don’t Forget to rate the Solution”
Jun 12, 2008 | Propellerhead ReCycle 2.1 (7350002920091)
ReBirth and Vista
Did everything above ,kept getting the same ol errors,i right clicked
on the app,opened properties,and changed compatibilities to win xp. then, instead of opening the rebirth from program files,i went and opened a demo song from the rebirth folder, and hey presto the ***** opened,after that the program would open the usual way.
yippeeeeeee........
Jan 21, 2008 | Propellerhead ReBirth (Virtual...
M-Audio Propellerhead ReCycle 2.1 (us920091) for PC, Mac Logo
151 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
