Question about Canon PIXMA iP1600 Printer
While replacing the ink cartridges a clear ribbon came off. What is this for . My printer is a canon pixma ip1600
  • 2,098 Answers
The printer needs to be repaired. That clear ribbon is an encoding strip and tells the controller what position the print head is in with respect to its travel back and forth across the platen. The printer will not work without that strip in place.
Posted on Dec 09, 2008
Loading ink cartridges
what are the numbers mentioned over the cartridges.
Jul 03, 2008 | Canon PIXMA iP1600 Printer
I have a canon pixma ip1600. I have installed two new cartridges from cartridge world that tell me there is no ink...but there is. how do I override the printer
It is possible you got unfilled cartridges from CW. You can have them weighed at the store to check. Also you may need to turn off the printer then turn it back on after a short while to clear the memory. from: C. Zimmerman [I like the name]
Sep 13, 2010 | Canon PIXMA iP1600 Printer
Cannon Pixma IP1600 is full and will not print, how do I fix it
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
4.Close The Cover
Oct 16, 2009 | Canon PIXMA iP1600 Printer
How do i reinstall the ink cartridge rubber ribbon that came off inside my canon ip1600 printer?
Usually, the best thing to do is go ahead and get a replacement ribbon. When a ribbon comes loose, it can sometimes snag, causing a tear, that tear can drop threads into your machinery, causing jams. If however the ribbon is alright, then you should be able to replace it without much effort. just make sure you load it into any guide slats (where applicable) and do not force anything in. Hopefully, you have the owners manual. If not, search the mfr website for a copy of that manual in PDF form or DOC form, or call their support line.
Jul 20, 2009 | Canon PIXMA iP1600 Printer
Canon ip1600
Dear hoppygink,
Canon pixma ip1200 series (ip1200,1600,2200) identify the first new cartridge installed in the printer and detects ink level properly unless you put another used cartridge or you its own cartridge to another printer. Once you do this, ink level of the cartridge become unknown. So, never exchange its own cartridge with another ip1600 printer. This will be back to normal condition when you replace with new fresh one catridge that never used before. This weakness has been improved by canon in pixma ip1300 series (ip1300 & 1700) anyway.
To prevent this problem occurs, you need to back up EEPROM data of the printer by using EEPROM restore tools before perform cartridge exchange. I will discuss this in Canon Inkjet Forum in the next coming chance. Please send me your email to: ijxpert@gmail.com so I can notice you immediately after posting the topic.
Regards,
Dec 12, 2008 | Canon PIXMA iP1600 Printer
Canon Pixma 600 printer showoing a green streak
You may running out of the colored ink.. just make sure you change it before it runs out.. make sure you buy a colored ink for Canon Pixma iP1600.. the cartridge of the colored ink of your printer has a number infront of it.. eg: Canon CI-41
Sep 21, 2008 | Canon PIXMA iP1600 Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Canon PIXM iP1600 ink replacement
Each time the cartridge is removed from the printer an "empty cartridge" message appears and a blinking amber light will come on, on the printer. Holding the paper feed button down for 3-5 sec. will allow you to override the counter.
Oct 26, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
93 people viewed this question
old marine
old marine
