Question about IBM Tripp Lite Internet Office 300VA (31P9552) UPS System
Increase run time on APC NS 600 (part # BN600)??
Apparently this unit is programmed to shut off at 60 minutes, no matter what the load. I am trying to run low wattage lighting (alert lights) for extended periods during power outages.
Is there a way to hack this?
3 Suggested Answers
crayzeetrayn
  • 837 Answers
SOURCE: loading speed and running speed
What have you used for spyware, malware removal? I would suggest you go to this link and download and run malwarebytes - full scan .. it will run in safe mode if you want to also ..
Posted on Mar 27, 2009
  • 367 Answers
SOURCE: We have a new 60
Yes this UPS will protect the TV and the DVR.
The TV is pretty energy efficient, and uses just under 100watts powered on. The DVR uses under 30 watts, so under heavy load you won't go over 150 watts if just these two devices are plugged into the battery backup side of the UPS. I'm not sure how long this UPS battery last's in a power outage, but since you are not using it to the full 360 watts, you should get double time out of it, though of course, its best to power off your devices as soon as you can. Regards, Chris
Posted on Jul 12, 2011
How to increase the time to 60 minutes for the technogym run 600 xtpro
If you wish to get some details about treadmill; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 20, 2016 | True Technogym Excite Run 700 Treadmill
I have a new APC Backup NS 1080
battery backup system guide
Oct 23, 2014 | Computers & Internet
Apc backups ms 600
why don't you replace the battery
May 11, 2014 | APC Computers & Internet
APC Back-UPS ES500. Battery is new replacement UB1280, and battery has charge and runs fine if unit not plugged in. However, if unit is plugged in to power back-up side outlets in unit don't work.
there are 2 parts of a UPS .
the charge side
and (battery is obvious)
the inverter side.
if the charger fails, all is lost. (are the batteries in backwards?)
if the charger works (volt meter tells you that)
then the inverter is bad. (this unit is not full time UPS , but part time, this means it switches over to inverter at power fail.
(on full time sys. inverter runs full time, like the name states)
the unit, you mean the load right.?
the UPS side plugged into a load. and the load is now dead.
the Backup plugs should work if the mains are hot.
if you kill mains, the inverter will fire off, (hear the squeal?)
and give you 500 watts for some minutes, sucking the batteries dry. (see load run time curves)
I used to do service on HUGE UPS systems, some with 100s of batteries. 3 to 5kw too.
on ours there is a port on the rear , we connect and can
check everything "BEST brand" even charge voltage.
did you look on APC site for special software and connections?
the manual does cover trouble shooting, ever read that?
RTM? start there, its online, for sure.
Oct 03, 2013 | APC Back-UPSĀ® CS 500 UPS System
How do you reprogram start duration for a longer time
You do realize that there are multiple remote starter manufacturers and, that these multiple manufacturers have different programming methods. However, the 12 minute run time is a default run time for Directed Electronics (Viper, Python, Clifford, Avital, etc) but, that does not mean that it is a DEI product. If it is a DEI product and you wish to change your runtime to 20 minutes, it can only be done with a BITWRITER. The installer should have this. The runtime settings that are optional without the bitwriter are 12, 24 and, 60 minutes for the more expensive units.
Jan 14, 2013 | Vehicle Parts & Accessories
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
We have a LG DLE2516W dryer. It does not get hot enough to dry clothes in less than two hours. We have checked the lint drap and the vent pipe. Both are clean. It does not matter whether there is a...
It could be a thermostat in the unit there are two and it could be registering wrong and shutting down the fire early. No way to check them though unless you put a tester on them while its running and see if they are shutting off the fire during a cycle
Dec 29, 2010 | LG DLE2516 Electric Dryer
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Buddy
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
IBM Tripp Lite Internet Office 300VA (31P9552) UPS System Logo
388 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
