Question about Sony Playstation 3 (PS3) Console
Nothing comes up on my TV when my PS3 is on
When I turn on my PS3, no picture appears on the TV, plus I get no sound. I am using standard definition A/V cords (yellow and white) and I want to know if I should upgrade to an HD TV with the HDMI cord (Which I would have to go and test first) or something else. I would please like to know this before Christmas.
P.S. I do not live in USA!
  • 1 more comment
  • yella 23 Dec 09, 2008
    nothing comes up on the tv when i turn my the power on plus it has no sound what can i do?
    when I trn on the ps3 i get no picture or sound what can I do
  • Anonymous Dec 10, 2008
    i need to know how to fix this
Blan start up screen
Posted on Dec 09, 2008
Ok, I've seen all the 8million freakin 'hold button 5 seconds' explanations. All the other explanations, but I see NOTHING, nothing at all on my tv screen. My tv is a Jan'04 model, is this...
I understand your frustration - my PS3 went through about a two week phase where it only read disks about a quarter of the time. It sounds like you have gone through a lot of the standard troubleshooting stuff, so I'm just going to ramble some facts and ideas and hopefully something will be able to help you!
- If your television works, there is no reason it wouldn't be able to host the PS3 system. There is a chance that it will not support full 1080p high definition, but the PS3 is still incredible in standard definition.
- Have you used any AUX input devices on your television before to confirm that the red/white/yellow input jacks work? And have you checked any documentation on your television to see if there is some way to switch to AUX input?
- If you've pressed the button for 5 seconds, the PS3 should be using its default graphics mode, and will be in standard definition using the cables, so that shouldn't be the problem
- If the regular cable TV is playing, there is a good chance the TV needs you to ask it to switch to a new mode of input manually - is there a button on the controller labeled "input", "source", or "AUX"?
If none of these are any help, I would recommend going on eBay or heading to the nearest GameStop and buying a new set of connection cables - there is a chance that is the problem, and is a lot cheaper than tossing the PS3 entirely! Good luck, and I hope I was able to help!
May 06, 2011 | Sony Playstation 3 (PS3) Console
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I turn on the console and nothing appears on my tv im using hdmi but if i use the av cords same thing nothing what can i do to solve this
    Hi there, please do the following to solve this problem :-
    Step 1. Turn the PS3 off into standby (red light on)
    Step 2. Press and hold the power button. It will beep as soon as you press it then beep again about 5 seconds later. Let go of the power button when you hear this second beep.
    Step 3. Wait for the PS3 to restart.
    This basically resets the resolution back to standard definition.
    Hope this helps and thank you for using FixYa
    Sep 12, 2010 | Sony Playstation 3 (PS3) Console
    When i connect my ps3 to my tv there is no picture but i can hear sound ive tested the wire with a friends ps3 and theres nothing rong with it and ive set it up on a difrent tv and it still had the same...
    Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
    Step 3. Wait for your PS3 to start.
    This solution basically resets the video output back to standard definition.
    Aug 22, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 wont show picture on any tv, even tried the old white, red and yellow cord and still nothing, any ideas on whats wrong with it?
    You have said you have tried the standard AV cable but have you reset the PS3 back to standard definition? Do this by holding the power button down for 5 seconds. It will revert to standard definition after that.
    Hope this helps
    Aug 02, 2010 | Sony Playstation 3 (PS3) Console
    Hdmi from PS3 doesn't get picture or sound on magnavox LCD TV but worked for the last 6 months fine.
    If the video output settings on the system do not match those of the
    cable or TV in use, there may be no picture. If the screen goes
    blank, turn off the system. Then, with only the system and the TV
    connected, press the system’s power button for more than 5
    seconds to turn the system back on. The video output settings will
    automatically be reset to the standard definition (SD) resolution.
    Jun 27, 2010 | Sony Playstation 3 (PS3) Console
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    Sound but no picture on PS3 using AV3/4
    the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
    Apr 05, 2009 | Philips Televison & Video
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
