Question about Brother MFC 210C All-In-One InkJet Printer
I have a Brothers Printer/Scanner.... I have not had a problem scanning until today. I can make a copy but cannot scan a copy and set it to file.
2 Suggested Answers
n25an
  • 622 Answers
SOURCE: I have a Brothers Printer/Scanner....
check if the ip address of your computer changed...and see if you can print... if you cann't print... then its a network issue... if your ip address changed then its a network issue... if its connected via usb... then reinstall the scanner and see if that helps...
Posted on Dec 26, 2009
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Its telling me no scan option
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab1
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Jan 13, 2009 | HP PSC 1210v All-In-One InkJet Printer
I have a Brothers Printer/Scanner.... I have not had a problem scanning until today. I can make a copy but cannot scan a copy and set it to file. wont scan i have a 110 brothers printer
Dec 24, 2008 | Brother DCP-110C All-In-One InkJet Printer
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Scanner
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Sep 04, 2008 | HP OfficeJet 6310 All-in-One Printer...
Hp scanner 3030
i have a hp 3030 all in one is there.. printer, xerox, fax is working properly but scan is not working .. kindly solv this problems..
Aug 31, 2008 | HP LaserJet 3030 All-In-One Printer
Scan copy to computer
Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
Scan Photos
u put ur picture on glass of scanner . and give command to scanne after scanning computer will ask in which format u like to save ur file
Jun 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 210C All-In-One InkJet Printer Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
