Question about Dean Razorback Db Electric Guitar
My Dean razorback V Standard keeps going out of tune and I have no clue how to fix it.
    Problem Solver:
  • 14 Answers
First, I don't know how long you've been playing guitar but you need to make sure the strings aren't old and/or not kept clean. The oils and skin cells from our fingers will cause strings to break down in there elasticity, therefore causing them to lose there retention (eg. memory). If you have a locking system with floating bridge then make sure your locks are tight, but not to tight as to strip or break the screws. Next, if you have a cheaper guitar, like in the $250 range, you will experience this more often than not, especially if you don't have a locking system. But just remember that guitars have to be retuned all the time (just watch live video of guitarists like Jimmy Page and Angus Young, etc.) if you play a lot and really play the instrument to the fullest (eg. Dive Bombs, EVH Horsie, Pitch Bends, etc.). Also, when you put on new strings they need time to stretch before they find that place where they retain their memory so it's a good idea to play and stretch the strings using various techniques like bending and whammy (EVH has been known to boil his strings to aid in this). Last, but not quite the least, if you find your guitar going out of tune after just a few minutes and after all my suggestions then your guitar may have a problem with its INTONATION, which you'll need to take it to a guitar technician which won't cost much and you'll be very happy with the sound. One last thing to remember, if you have a cheaper guitar without locking system they're really not capable or designed for using the whammy bar that comes with most of them---this is just a feature for helping to sell the guitar because everyone wants a whammy bar---the guitar will go considerably out of tune everytime it's used. Hope this long explanation helps.
Posted on Dec 13, 2008
How do I put the springs in my dean razorback 255
I'm sure you have solved this by now, but I would recommend hooking the straight pin of the spring into the 1st, 3rd, and 5th holes on the trem, then hook the loop ends to the three center claws. This gives a variable or progressive rate of resistance, letting the trem gargle like Vai or Dimebag, but resists going out of tune.
Apr 22, 2013 | Dean Guitars Dean Razorback Guitar,...
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
Dean razorback db electric guitar knobs
the knob closest to the neck is your volume. And the other two are tone. one is tone for bridge p/u & other is tone for Lead p/u. which is which can vary. you'll just have to listen. hope this helps
Jan 31, 2012 | Dean Razorback Db Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
How do I change the intonation on my dean dime razorback?
There are good videos of guitar setup on YouTube. Search for them.
Dec 03, 2010 | Dean Razorback Db Electric Guitar
How do i intall my Seymour duncan Dimebucker in my Dean Razorback guitar?
Here is their site:http://www.seymourduncan.com/support/choosing-installing/installing-pick/ Don't be shy about contacting them:http://www.seymourduncan.com/support/contact-us/
Jul 10, 2010 | Dean Razorback Db Electric Guitar
My string is kinda hard to bend, i use .09 - .46,
Try using a lighter guage set of strings and set the action a little higher if you need to. our local guitar shop should be able to give you good advice and do the setup for you if you need it.
Mar 14, 2010 | Dean EXplosion Razorback Electric Guitar
Kinda dumb but my razorback has three knobs, tone treble and volume, although when i turn any one at a time all the way off the guitar is not silent. Is this normal?
It very well may be. Sometimes the volume is arranged so that it will not go clear down... Hey, it saves the manufacturer a lot of calls saying there is no volume by people who forget to turn the volume up.
Dec 10, 2009 | Dean Razorback Db Electric Guitar
Dean razorback DB problem
If the neck of the guitar is a bolt on neck (their will be a plate holding the neck onto the body of the guitar with several screws) then this is typical. Some strings will give off small vibrations. Nothing is wrong with the guitar, usually with a string change or with time the tone will fade as the strings change to the shape.
Hope this helps,
-Aaron C.
Jan 25, 2009 | Dean Razorback Db Electric Guitar
Dean Razorback Db Electric Guitar Logo
469 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Rick Moore
Rick Moore
Tom Rood
Level 1 Expert
Are you a Dean Music Expert? Answer questions, earn points and help others
