Question about Toshiba Satellite M45-S2692 Notebook
I need help fast.
I have a Toshiba Satellite M45-S269, it powers on but goes completely black. I know to try and reboot it with the recovery disk that came with the computer , but about a week before that happened my computer stopped recognising my cd drive. I need to know is there a way for me to boot it from an external cd rom drive? p.s. I went into my system bios and switched the booting priority to cd-rom first but that didnt work. As far as usb foes I only have an option for usb kb/mouse emulate and usb-fdd. Am I just screwed?
  • Jessika Mullen Feb 25, 2007
    Ummm my first question may have made me seem like i knew what i talking about but im not the great with computers. i have a few ports in the back which one is the vga. and do i need a special kind of cord to do this. because i have hooked it up to an external monitor using a seriall port but the same thing happened black screen.
    Any more ideas? :(
I am an IT person, but not familiar with Toshiba products; have a friend's S269 that does the same thing....no video, either internal or external.
Friend says went blank while he was trying to hook up a TV set to his Svideo connection.
On/off switch just recycles, won't stay off.
Eliminated battery.
Have ordered new memory stick to ensure it isn't that, but symptoms point towards motherboard or bios.
Am puzzled by the on/off switch recycling.
Posted on Jan 28, 2008
  • 624 Answers
Booting to an external USB drive depends on your BIOS but as far as your monitor goes have you tried plugging an external monitor into the vga port in back yet? It may be that your backlight is non-functional and an external monitor will give you the work-around you need.
Posted on Feb 25, 2007
  • tomj23 Feb 25, 2007
    Sorry, the VGA connector is about 1? long, probably blue and has three rows of holes where pins from the monitors VGA cable will fit. If you have a working monitor plug it in and fire up your laptop. When you see something display on the laptop monitor hold the FN key down then hit the F5 key. Usually hitting this key sequence once activates the external monitor, a second time disables the laptop display but leaves the external on and a third time disables the external and activates the laptop display.
Fix it diagram owners manual for toshiba satilitte M45-s269
Try running check disk.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.------------------------------------------------------
If check disk does not solve the problem then you'll have to reinstall your operating system.
Apr 02, 2012 | Toshiba Satellite M45 PC Notebook
PXE-61: Media Test failure, check cable
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
M45-s269 battery
any how i hope the above helped (refer to comment) and happy computing
Feb 03, 2012 | Toshiba Satellite M45-S269 (PSM42U016006)...
Having problems rebooting from recovery disk
The laptop should have a hidden recovery partition on it to return it back to factory settings.
Make sure the laptop is switched off and then press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear.
If there is no recovery partition then to get it to boot from the CD/DVD drive repeatedly press the F12 key as you start the laptop up.
If you need anymore help please post back.
Regards.
Jun 28, 2010 | Toshiba Satellite A135-S2276 Notebook
Cq50-112eo bios flash Problem
hate to tell you you messed it up big time.you never interrupt a bios flash. best i can suggest is to stick in your recovery disk and try to do a recovery.
Mar 23, 2010 | Toshiba Satellite M45-S269 Notebook
Satellite M45-S269 Power connectivity
Either defective AC adapter or DC connector(common problem) needs to be replaced
Mar 24, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S269 AC Power Adapter
no it isnt normal and isnt safe either. DONT USE IT! Buy a new one on ebay and throw the other one in the trash.
Mar 13, 2008 | Toshiba Satellite M45-S2692 Notebook
Lost CD-Recovery
If you are speaking for your laptop, double click my computer and see if you have a D drive, most newer computers have a partition on the hard drive that has the recovery feature installed on the D drive. You would need to boot in the SAFE mode if possible and go to the D drive and run setup.exe. If this is not possible, you will have to purchase a new operating system CD and probably have to download drivers from Toshiba for your laptop. Good Luck - BPCS
Dec 13, 2007 | Toshiba Satellite M45-S2692 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
