Question about Kenmore 62602 Electric Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
My Whirlpool dryer Ultimate Care II (model GEQ9858JQ0) will not stay on when the start button is pushed. Holding the start button down will keep it running, but it will not heat up and the timer counts down very quickly. Could the cold temperature (about 38-40F in the winter) in my basement have anything to do with it?
Thanks for any help
  • 36 Answers
Sounds like the motor or the even heat board is out i would say the even heat board is more likely
Posted on Dec 09, 2008
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool ultimate care ii dryer, only works when continuosly pressed the start button. What can be the problem. whirlpool ultimate care ii dryer model gew9878lw0
    More likely than not either the start/run switch on your motor wen't bad, or the motor windings itself. Either way you need to replace the motor #279827 around $100 on up.
    Not tough to get to if you know how to gain access to the cabinet, just remember that the blower wheel and motor threads going into the blower wheel are LEFT hand thread,
    have fun, and best of luck,
    ttfn
    Feb 04, 2010 | Whirlpool Dryers
    Whirlpool Ultimate Care II Dryer timer knob
    The timer cam is not aligning the internal switches. Replacing it is the only fix.
    Eric
    Sep 17, 2009 | Kenmore 62602 Electric Dryer
    Whirlpool ultimate care II stops after filling
    Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
    Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
    HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
    Oct 07, 2008 | Dryers
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
    The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
    Jan 23, 2008 | Dryers
    Kenmore 62602 Electric Dryer Logo
    319 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De GO PATS
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
