Question about Sony DRU-710A DVD±RW Dual Layer Burner
How to Install Sony DRU-710A DVD-RW
Windows recognizes that the device is there. It reads a disk then stops and won't install the drivers. Is there anyway to force the drive to read the disk to install the drivers. When I search on the internet and download a program that scans for drivers it says that it's a good driver. Also when I try to view drive D where this drive is, it is not showing on My Computer. Please help in anyway that you can. Thank You.
    Sergeant:
    Novelist:
  • 192 Answers
Cd/dvd drives don't actually require a driver to run. They use "class filter drivers" which are supplied by a burning program like Nero or NTI. These "class filter drivers" only add functionality to the drive. Windows just uses a generic driver "MSCDEX" to run them.
A couple of things to try:
Uninstall the drive. Open Device Manager, click on the + sign next to CD/DVD ROM drives, right click on the drive and select uninstall. Exit and restart your system. When windows loads, it will recognise a hardware change, and will ask if you want to install. Before you click anything, insert the disc that came with the drive (if you have one). This should then install, if not, let windows search. If windows can't find anything, select "I will choose the driver manually" and look for your drive in the list.
Another thing to do, is download the most current Chipset drivers for your motherboard (which I would recommend anyway, even if the above worked).
Update the Firmware version and the internal drivers for your drive. These can be found here: http://sony.storagesupport.com/product/112#drivers
Also, update windows to the latest Service Pack (SP3 for XP and SP1 for Vista) if you haven't got them already.
If you have Vista, did you recently update to SP1 via Windows Update? If the answer is yes, please let me know.
Hope these solve your problem
Regards,
Tim
Posted on Dec 10, 2008
Sony DRU-710A Installation without the disc.
check sonys website for the drivers for it. If not try what you said. Good luck.
May 24, 2009 | Sony DRU-710A DVD±RW Dual Layer...
Wont Read OR Burn DVD's
Hi There that is a hardware failure inside the unit there are two different lasers in the one head one for cd and one for dvd it sound like the dv d head has failed if the unit is new or under warrenty its time to speak to your supplier or if not bite the bullet and invest in anew unit
sorry for the bad news
Regards AL "Alstech"
I have window xp my dvd burner worked fine before now it doesnt
What do you mean "it just stays there"? Can you be a bit more specific? The writing speed doesn't really mean anything apart from being able to burn quicker.
The "drivers" for the sony dru 710a can be downloaded from here:
I would also update the Firmware version too.
Hope that works
Regards,
Tim
Nov 14, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Instalaion
You don't actually need a driver. All cd/dvd drives are plug and play. All you need to do is plug it all in to your system, turn it on, and Windows will do the rest. Once Windows has installed it. You can update everything from here:
Hope this solves your problem
Regards,
Tim
Oct 28, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-710A DVD±RW Dual Layer Burner?
First I need a little more info from you, what operating system are you using( windows XP,Windows Vista,Linux?) What software are you trying to burn the DVD with?
What Happens when You try to burn the DVD,Do you get errors or crash or what?
Let me know I can see what I can do to help
wwiz
Oct 13, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Power caliberation error
Try uninstalling your burning software and then re-installing it.
Try uninstalling your drive, restart, and let Windows install it.
Download and update your Chipset drivers (recommended)
Update to the latest Windows Service Pack (recommended)
Uodate the drives Firmware version and internal drivers:
Regards,
Tim
Aug 25, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-710A doesn't write others than DVD+RW anymore
I updated the latest firmware provided by sony and could solve the problem.
Regards
Hannesfx
Feb 10, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU 710 not writing DVDs or CDs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking Sony for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays
Jun 20, 2007 | Sony DRU-710A DVD±RW Dual Layer...
Problems recording DVD-R 16X
Try this download page to update your firmware from 25/10/05, so if you bought your writer before this date maybe this will work, otherwise buy 8x discs. http://sony.storagesupport.com/dvdrw/firmware.htm#710 The faster the discs are burned the more chance of errors there are, you should write at slower speeds for better quality.
Oct 27, 2006 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-710A DVD±RW Dual Layer Burner Logo
349 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
