Question about RIM BlackBerry Curve 8310 Smartphone
My camera on my blackberry curve is not working. ]
It has strange looking colors and the pictures are not saving.
  • 3 more comments
  • Anonymous Jan 26, 2009
    I have strange looking colors on my camera now and it won't take or save pictures...Any clues ?? I tried plugging it in and taking a pic and that will not work either..Please help.....
  • Anonymous Mar 02, 2009
    Camer view finder shows red tint and the file that is saved does not show a picture
  • Ross Cannatello Apr 14, 2009
    i have the same pronlem but i replaced my battery and it still does it..i tried updating it and still nothing..please help!!
    my blackberry curve will not store pictures..the view finder has a redish/white tint..it snaps the picture but when i go to view it there is no picture just a box with an x in it..i replaced the battery and have updated software too..please help!!!
  • Anonymous May 03, 2009
    My Blackberry Curve 8310 camera stopped working - viewfinder shows bluish tint and picture is blank. It is only a few months old and worked when I first got it. Plugging it in makes no difference.
I found this solution on Blackberry forums. You'll need to take the battery cover off, and then push on the camera lens, or more accurately, the ring surrounding the camera lens. You should see the image corrected. I just tried it on mine, and it worked like a charm. Easy, cheap, quick fix.
I'd be curious to know if it's an electrical problem, a lighting problem (most likely) or a physical lens issue (focus).
Anyway, try it - it should work.
Posted on May 21, 2009
  • megsani Nov 11, 2010
    Yes it worked for me too. I almost gave up. Thank you. An important lesson to remember and remember always: never give up no matter it seems that you have hit a wall. Give a try, next time with a different approach/solution.
  • rag1pv Mar 28, 2011
    Brilliant ! This solution is awesome. Worked on my blackberry like a charm. Why don't the blackberry engineers wake up and fix it..obviously it looks like a very common problem
My blackberry curve 9300 won't let me take pictures , if i try and open camera it says 'Could not start the camera. Close other applications and try opening the camera again.' theres no other applications open and it won't let me and i've tryed turning it off, what do i do?
Posted on Jan 01, 2011
  • baileyt10 Apr 09, 2011
    Yh same here m8 and I would like to know how to fix this aswell
Pushed on my lens and it did fix the problem, weird but it worked. thank you so much!!!!!!! :)
Posted on Feb 28, 2010
  • 3 Answers
I had that happen concurrently with a battery failure. When I made calls, there was a lot of interference and it died after only a few minutes of talk time. Also, my camera came up with strange, bright (pink, yellow, white) colors. I assumed it was a battery problem because the symptoms dissapeared when my curve (8320/ unlocked t-mo on rogers) was plugged in.
I replaced the battery for about 20$ on-line and everything's been fine since.
Hope it helps.
Posted on Dec 29, 2008
2 Suggested Answers
SOURCE: my camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Posted on Jul 03, 2010
My curve is locked in camera mode. My daughter presses "something" and I cant get out of camera or snap a picture to get out of camera or go back to home screen. power down didnt help - help!!
Reflash your blackberry phone, it should be works and will make your blackberry camera curve 8300 unlocked. If that solution not working, bring your phone to nearest mobile phone repair shop and asking them to unlock blackberry using cable unlock. It's not only unlock your camera but also unlock your network if successful.
Mar 06, 2011 | AT&T Blackberry Curve 8300 Smartphone
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
My curve 8330 will not give me the option of storing camera pics to the media card. The only option I have is devise memory.
Here is the solution.
Press the Menu key
Click Options.
Select Change the Store Pictures and Folders
Press the menu key
Click save.
Hope this helps!
Oct 25, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry will not send pics as mms
The BlackBerry device user is unable to send photos taken with the BlackBerry device camera in Multimedia Messaging Service (MMS) messages, because the photos taken by the BlackBerry device camera may be too large to send in MMS messages.
Reduce the size or quality of the photo and resend.
To access the size and quality options for the BlackBerry device camera, complete the following steps:
  1. Open the Camera application.
  2. Click the menu button.
  3. Select Options.
  4. Change the Picture Size and Picture Quality settings as required.
  5. Click the menu button and select Save.
And try to send the photo in an email message instead of in an MMS message.
Oct 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry 8900 cant save pics 'file system error'
A file system error displays when saving a picture taken with the camera on the BlackBerry smartphone
Cause
The folder in which the BlackBerry smartphone saves pictures is a read-only folder.
To resolve this issue, complete the following steps:
  2. Display the menu and click Options.
  3. Click the folder listed in the Folder field.
  4. Continue clicking Up until Media Card and Device Memory are options.
  5. Click Media Card or Device Memory.
  6. Click Select Folder.
  7. Display the menu and click Save.
Aug 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
6,417 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
