Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Need a new lamp
Read how to reset the timer and have made notes but I also need to replace the lamp according to the tv screen. Where can I purchase the lamp at a reasonable price or is it better to just get rid of tv? Thanks,
  • 3 more comments
  • tomylake Dec 11, 2008
    Information was helpful but I will need to find a new lamp as it is definitely bad.
    What numbers do I need to type in to make sure that I get the right lamp? Do I need nust the lamp number or model of tv?
    Thank you so much because I thought I should google the PT40LC12 number to order the replacement bulb but with your info, I realized that I need bulb TY-LA1500. When I removed the cover, replace with this bulb. I will try to google and if not successful, I will write and ask for your help again. Thanks again, Jen
    There are such varying prices on these replacement lamps, does that mean that some lamps are better than others. I would rather pay a little more and get a good lamp rather than pay less and get one that will blow in a year. Thanks, Jen
    How will I know if it is just a bulb or the complete set? Is it hard to remove the bulb from the casing and replacing it with a new one? How will it be listed so I will know if I am getting a bulb or the complete set when I google?
  • 106 Answers
If the la,p still works, just reset the timer and wait for the lamp to go bad, Which it will do eventually, but lets not fix it if it ain't broke. In the mean time you can find that lamp online anywhere and by the time you have to buy one it may be a little cheaper. If this helps please take a few minutes to rate the response. Thanks
Posted on Dec 09, 2008
  • 1 more comment
  • tvguy171
    tvguy171 Dec 11, 2008
    You can do one of two things, first, give me the model number and I can provide a part number for you or you can just google you model number with lamp and you will get several response with the part number. Either way will get you taken care of
  • tvguy171
    The big difference in the lamps will be whether they have the enclosure or not. If you buy a bare bulb (it will be cheaper , about $130) you will get just a buld and have to remove the old one from the casing and install the new one. For more money, you will get the buld and the casing as a complete package. I usually get a bare bulb and install it in the case myself
  • tvguy171
    When you google the lamp, you will see the words "bare bulb". That is the bulb by itself. You can use a srewdriver (philips head I believe) to remove the old bulb and reinstall the new one. Just remember where the screwa go and DO NOT touch the bulb with your bare hands. Use a pair of gloves. The oil from your skin could cause the bulb to go bad. I know it's hard to believe but it's true.
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Tip
Procedure to reset Panasonic TVs
If you have replaced the lamp in your Panasonic DLP TV and are having problems such as a message on the screen telling you to reset the lamp timer or the unit not powering up, you probably need to reset the lamp counter. All DLP and LCD TVs which have high intensity lamps generally need to have a lamp timer circuit reset after a lamp change. The manufacturers want to give you a heads up prior to having a catastrophic event such as a lamp exploding which could cause a fire as well as other damage.
Therefore in many cases until you reset the lamp timer the unit will not operate or it will keep reminding you to reset the lamp timer which is very obnoxious. This is not a hard procedure but you will need the original factory remote to accomplish the task. Generally the procedure involves pushing a sequence of buttons.
I recommend placing a piece of masking tape on the rear of the TV with the date the lamp was changed to make it easy to remember when the next lamp change will be necessary. Also you could purchase a lamp now to avoid paying more in the future.
The following procedure should solve your problem:
1. Turn on the television.
2. Press the down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 28, 2010 | Televison & Video
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
Sep 21, 2009 | Televison & Video
A warning pops up on the screen of my Panasonic PT50LC13 That my lamp needs replacing and I need to reset the lamp timer, how do I reset the lamp timer?
After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
Aug 19, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset lamp's timer
You will have to purchase the Service Remote in order to reset the lamp hours on that model.
Jul 20, 2009 | LG RU-44SZ61 44" Rear Projection...
Sharp TV Flashing Codes
did you purchase just a new bulb? or did you buy the bulb with the cage included?
Oct 21, 2008 | Sharp 56DR650 Television
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
183 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
