Question about Nespresso Aeroccino Automatic Milk Frother
Power OK to base, but frother has no power
I heated milk without the frother yesterday and this morning, the frother doesn't work. The light doesn't go on, but when tested,the base has electicity. Do I need to replace the whole unit or is there some way to open up the bottom and repair something inside? Thank you!
  • 4 more comments
  • planitbc Dec 09, 2008
    I heated the milk without using the little whisk thingy. I wanted hot milk, no foam.
    As I mentioned,the base tested positive for electricity, but still the unit doesn't go on.
    Does that help?
  • kdwinnett Dec 09, 2008
    I have frother and have used it with no problems for several months. Went to use this morning and it didn't turn on. I pushed the button and nothing...
  • qualistat Jan 02, 2009
    exact same problem. Worked fine for 3 months.
    We didn't leave it on the stand plugged in, so that ca't be an issue.
  • Anonymous Jan 24, 2009
    Same thing..
    Made one coffee, poured out the milk, second coffee- no action.
    I only bought it 3 days ago
    I think it froths really well, pity it has such a short life..
  • Oby Claus
    Oby Claus Nov 08, 2016
    Thanks! I've been Googling for days since my Aeroccino stopped working. No power at all. After trying it on another base (my girlfriend has the same machine) I knew the problem was the Aeroccino.
    I pulled it apart pretty easily. No video I saw on Youtube told me to pull the button out first which would have made it even easier. I couldn't see any obvious problem and I hadn't read this post so I didn't know about the thermal fuse under the plastic sleeve along the red wire.
    Tada! There's my problem. Checked it with my multimeter and the fuse is dead.
    $3.50 from Jaycar for a new fuse tomorrow. Fingers crossed I don't pull out my old soldering iron and find out that's busted too.
  • James Sansangasakun
    James Sansangasakun Nov 28, 2016
    Same thing's happening to me as well. I was just making one coffee for my wife and it just stopped working for mine. I'm ordering this fuse from ebay.http://www.ebay.com/itm/181718434647 Hope to see it shipped soon.
    Any tip taking out the old fuse from the binders? I am not an electrician, not sure what tool I should use.
My frother was working several month without problems. I love that! Someday i try to turn it on - nothing. I opened the frother and found out the the thermal fuse was broken. The specification for that fuse is 108°C/5A 125V~. The fuse you found in the red wire - there is a transparen tube to protect the thermal fuse contacts.I replaced the fuse - it worked !
That means the frother was overheated. The fuse has done the job.
Posted on Mar 19, 2009
  • alforno Jun 11, 2011
    Thanks Schloess but how do I get the base off
  • johnnie123 Jul 14, 2011
    Please how do you get the unit open. I took the base apart and did not see a red wire or a transparent tube so assume it is in the main unit.
    Thanks in advance for any help.
Nespresso milk frother instructions
I had the same problem. From reading various sites it is clearly a common problem. Most suggest phoning Nespresso to get it replaced but one website suggested turning the machine upside down. Not the base, just the aeroccino. Leave it like this overnight and it resets itself. I don't understand how that works but I tried it as it was a weekend and wasn't going to be able to call the helpline till Monday. And it worked! I now have proper froth again. Other suggestions seem to be try never to get the underneath wet (I think leaving it upside down ensures this area dries out completely), don't leave it on the base when not using and certainly don't leave it on.
May 19, 2013 | Nespresso Aeroccino Automatic Milk Frother
The milk frother has stopped rotating.....the milk heats but the frother doesnt rotate hence no froth.... am in india,mmbai so dont know where i can fix it !
The solution to rotation issues with the frother have been soved finally by myself after reading all the suggestion. The fix is simple... Your attachments have been magnitised and need to be demagnetized. It works a beauty. Run a magnet around the metal rings. Hint. Never leave them on the the frother when not being used.
Jul 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
The milk doesnt heat up or froth but the button flashes red
We had the same problem with burn marks on the bottom and flashing red light etc. Now we just rinse the container out with cold water each time we use it - do not dry, just leave it wet and then add your milk. Heats up perfectly each time. The water lubricates the base of the container, preventing burning. Nice hot coffee every time now. Hope this works for you too!
Apr 20, 2011 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Jan 09, 2010 | Coffee Makers & Espresso Machines
Cannot ventilate machine
Sounds like the milk frother is blocked.
Remove the frother completely,try to ventilate without it.
You should be able to see through the center of the frother.
If not try to clean it out with a paperclip or pipe cleaner.
Dec 27, 2009 | Gaggia Titanium Espresso Machine
The milk frother is making the milk spit out of the jug and not producing any froth it used to be fantastic.
Check the end of the frother,ensure the center is protruding.
If not remove the lower end of the frother and push the center towards the end and click it into place.
This is a very common problem.
Oct 21, 2009 | Gaggia Classic Espresso Machine
Nespresso Aeroccino Automatic Milk Frother Logo
2,121 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
