Question about Samsung SGH-T339 Cellular Phone
I lost the phone and when I found it the battery was dead. After a little bit of charging the phone would only come up with a white screen that says "SGH-T339" but wont go past that.
    Problem Solver:
  • 13 Answers
My step son had the same issue. I removed both the SIM card and memory card from the phone before turning it back on. Once the phone got past the "SGH-T339" screen it tells you to install the SIM card. Remove the battery and install SIM card and turn phone back on. It has worked ever since.
Posted on Apr 19, 2009
    Problem Solver:
  • 16 Answers
Check to sse if the moisture indicator under the battery has been actiavted by removing the Battery, you sehould see a colored dot if it got wet.
Posted on Dec 09, 2008
I didn't charge my phone last night so the battery is completely dead, phone powered down and turned off-I have it plugged into the USB on my computer and I can't tell if it's charging, it won't turn...
disconnect your phone from your computer again, it would take time to charge there, remove your battery, let it cool a little bit and return it back, and charge with your charger. after 5 minutes switch it on and check.
Feb 24, 2010 | RIM BlackBerry Curve 8310 Smartphone
I have had this charging overnight but it won't charge. What should I do?
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Oct 30, 2009 | Toshiba e310 Pocket PC
My nokia 6220 wont start. When holding down the "on" button it just vibrate a little and the screen lights up a little bit, then it goes back to completely black again
The battery cell may be completely dead and you need to replace the battery. Because its going completely black again means its actually completely of. So try and change the battery, but make sure you charge it till its completely full before usage. Hope that puts a smile on your face.
Oct 13, 2009 | Nokia 6220 classic Smartphone
Sony Ericsoon W810i when the battery run flat I would charge it with a wall plug as ussual but this time will not charge. I changed charger and the same problem. the phone is dead. when I take out the...
Your phone needs reflashing. It seems that your phone's GDFS is dead. If you still have a warranty for your phone than take it to the Service Centre and they will do it for free. If you don't have a warranty than it will be a little expensive.
However you can flash your phone by yourself FOR FREE using SeTool2.
Read the rest by yourself:
http://www.akshayy.com/sonyericsson/tutorials/red-light-blinking-dead-revive-it-to-life/#more-35
Oct 01, 2009 | Cell Phones
My Motorola phone Will not charge
replace battery - sounds liks the battery is bad
Sep 08, 2009 | Motorola Mobility RAZR V3
Screen is always white when it comes on cant get it to work
You need to reflash the fw. It takes a little bit of work. look for dead phone flashing
Oct 28, 2008 | Nokia 6133 Cellular Phone
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Charger port problem
http://www.accessorygeeks.com/universal-travel-charger.html
or google BTC-UNI
iT'S little cheesy but hey for $10 and free shipping I can eat a lot of cheese.
Just plug your battery into this little clugy thing, plug the thing into the wall, wait until battery is charged and then put your battery back into your phone...presto...for this kind of money who cares if the VX9900 has a dead battery charge port.
I bought two, they were on sale for $7 each. It's ugly and takes a bit of patience but it works.
Feb 26, 2008 | LG enV VX9900 Cellular Phone
Fone dead
yeah wokka i had the same problem.what you do is...turn your phone on so it go's to that white screen take the cover off the back and take the battery out while the phone is on,thus cutting the power then plug into charger with the battery out,it took me a bit of stuffing around to get it to work.so just keep taking the battery out then after a few times put the battery back in the phone and plug the charger in without turning the phone on.if the little screen on the front lights up with the "charging sign"then switch the phone on and it should work. if not keep trying.dont know how or why this works but it worked for mine...which was good because these phones take such a great photo only thing that lets them down is that dodgy swivel camera which stuffs up after a while.hope this helps tho....
Jan 14, 2008 | Samsung SGH-Z510 Cellular Phone
Motorola razr v3 white screen problem
try the new battery, but be sure it the right battery and fully charge V6.0 or higher. if no change, than you may have damage on the inside from the liquid discharged (short)
Nov 30, 2007 | Motorola Mobility RAZR V3
Samsung SGH-T339 Cellular Phone Logo
209 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
