Question about Benwin ARC USB-P Computer Speakers
Brand New Sound System
Right out of the box: The right speaker input does not work, playback is distorted and not worth me keeping the speaker "on." I thought it might be my computer sending only a mono out but my cheaper speaker system plays fine. I will figure this out. Maybe my inquiry will help the next fella. Hope this company is worthy. Benwin Arc 2.1 with Sub
  • 100 Answers
You should refer to the store you bought it from.
Posted on Jul 31, 2007
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
How do I fix low volume sound on Dell xps 8500
guess we both need hearing aids my asus has same fault .
Mar 03, 2015 | Dell Audio Players & Recorders
My audio cannot work,no sounds
Desktop or Laptop ?? and operating system ??
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps. Laptop If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 05, 2013 | Microsoft XP Computers & Internet
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Feb 16, 2012 | Harman Kardon Audio Players & Recorders
HK 2.1 analog system with Windows 7, worked flawlessly no problems, moved and reconnected system but no audio. Have tested speakers separately, reloaded drivers, have done a system reset, done an entire...
have you configured the speakers?
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
hope this helps you
Sep 05, 2011 | Harman Kardon Audio Players & Recorders
Someone is trying to sell me a Panasonic Home Theater system SC-HT900 from year 2005 for $200.00 Is it a good system, is it also good for listening to classic and jazz or just for movies? how is the CD...
here it is some tech info ..it is a fair price for 2.hand unit...
as ebay has the similar prices..it seems to be a good deal...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Product Features and Technical Details
  • Dolby Digital, Dolby Pro Logic II, and DTS-decoding home theater receiver with 5 speakers and a powered subwoofer
  • 35 watts per channel x 4 "tallboy" speakers, 140 watts for the center channel, and 150 watts for the subwoofer
  • High-resolution DVD-Audio playback; JPEG, MP3, and WMA CD playback
  • Magnetic shielding for distortion-free placement near a TV or computer monitor
  • Includes digital FM/AM tuner and a universal remote control
Technical Details
  • Brand Name: Panasonic
  • Model: SC-HT900
  • Output Wattage: 390
  • Component Type: Home theater system
  • Audio Output Mode: Surround Sound
  • Surround Sound Effects: Super Surround Sound
  • DVD Type: DVD changer
  • Built In Decoder: Dolby Pro Logic II, Dolby Digital, DTS decoder
  • Remote Control Description: Universal remote control
  • Optical Digital Input: Yes
  • Audio Input: None
  • Tuner Technology: Digital
  • Radio Bands Supported: AM/FM
Jun 21, 2011 | Panasonic Home Theater System System
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
Same prob, using control panel sound mic off does not work
Right click on the speaker in the bottom corner (or go to sound in the control panel) and go to playback devices. Then click speakers, then click properties. Go to the levels tab and mute/lower the volume of the microphones.
Aug 28, 2009 | Compaq PC Microphone (Black or Beige)...
No sound on speakers
hi, make sure the speakers are connected into the right input slot. Secondly right click the sound icon near the clock and select properties/playback devices and make sure the speakers are set as default.
May 27, 2009 | eMachines D3415 PC Desktop
Benwin ARC USB-P Computer Speakers Logo
56 people viewed this question
Top Benwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Benwin Audio Player and Recorder Expert? Answer questions, earn points and help others
