Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
Valve spring broke
Where can you get parts at for a sumec linhai engine. engine family 5slhs 1711ga:em
Http://www.arkansas-ope.com/ENGINE_SPE175.html
Posted on Jan 06, 2009
Not sure but I think someone told me it is a knock off of the Honda? If so maybe try comparing? Ck size, Spring tension & etc?
I know not much help but that's where I'd start. Been told by a local small eng shop there aren't internal parts available for the Sumec engines.
Mike
Posted on Dec 15, 2008
  • 4 Answers
Sumec Machinerery & elec 1-800-445-1805. also check http://www.powermate.com/productmanuals.php?cat_id=3. you can down load the manual and parts list for your gen. their phone number is listed on the manual. i just ordered a carb from them for my PMO106001
Posted on Mar 27, 2009
Linhai 260 scooter wiring diagram
Hi, Howard for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Linhai 260 scooter wiring diagram Google Search
Linhai 260 wiring ScootDawg Forums
Linhai Aeolus 260 300 Scooter Service Manual $10
260cc Yamaha Linhai Based
Linhai Aeolus 260 2016
Jul 16, 2017 | Linhai Motorcycles
Linhai 260 wiring diagram
Hi, Howard for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Linhai, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Linahi Aeolus Scooter Parts
Rigid 3300psi Pressure Washer chokes after engine warms up. Then looses water pressure. What is the problem and can I fix it?
if the engine slows then so will the pump... and so will the pump power.
engines are all the same and so just google "servicing engines"
an engine requires fuel - air - ignition and compression......
if your engine starts and runs then it must have reasonable compression so check / replace / clean the fuel and air filters...
check the condition of the spark plug / clean it / replace it
after these basic checks you move onto measuring the compression and checking the carburettor which requires a level of skill you may not have
oh, check the oil too !
if you have a make and model of engine (not pressure washer) the manufacturer may have service kits and service manuals... briggs and stratton / honda / tecumseh (you'll be lucky) / sumec linhai
Aug 30, 2013 | Legacy Extension,angled Rigid - LEGACY
2006 Linhai Monarch 125 starter motor turns but does not engage the engine
Hi, Kos_vip the starter clutch is a separate mechanical gear driven component that is activated by the starter motor, it engages the clutch pack gear or the flywheel gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one "ONE DIRECTION" only and once the engine starts allows the gear to free spin with engine rotation. If the starter gear free spins in "BOTH DIRECTIONS" then the drive gear has failed, it might be serviceable on some models but usually needs to be replaced.
Starter spins but doesn turn the engine
Starter spinning but not cranking motor
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Chinese Scooter Parts Diagrams
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Nov 23, 2017 | 2006 Linhai Monarch 125
This is a 4cyl diesel Beetle. The timing belt broke while driving. Dealer claims no damage done, replaced belt and car was driven for a few weeks. Began to start a bit sluggish, dealer said glowplugs...
my books show it as a interference engine in which case valve damage is most likely to occur
however if that was the case , it would be having a miss from the start and would not run 2 weeks before something happened
if a valve spring breaks there could be valve piston contact but it is doubtful if that would destroy the engine but again breaking valve springs is rather rare on diesel engines
the engine would not just quit but would rattle and bang it's head off then develope a big noisy miss from a hole in the piston
so I suspect a timing belt problem from when they removed/replaced the head after the glo-plug fix or a crank/cam shaft position sensor or wires ( possible faulty connections for the cam shaft)
I would suggest finding an accredited service center for a proper diagnosis and quote for engine repairs
Apr 12, 2017 | 2003 Volkswagen Beetle TDI
They are saying it dropped a valve - what does
Can't say if it's common as I have little experience with your engine in particular, but a dropped valve usually means a valve spring broke and the valve is colliding with the piston. This would also cause the engine to run rough as there is no spring pressure to close the valve. Piston damage is not far behind (major repair).
Oct 25, 2009 | 2005 Volkswagen Microbus
Screeching noise from eng? dry bearing? Brass(?) dust in oil?
Hi
I think there is an engine problem.Disassembly entire engine and check all the parts inside(the cilinder, the crankshaft,the piston,the conecting rod,the piston rings,the camshaft(pay attention to the timing points at the gears),the oil pump,the gaskets and so on.
best regards savumihai71
Nov 25, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
594 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
