Question about BenQ PB6100 Multimedia Projector
Super video and composite wont work with progressive dvd
It does work with component, but why it wont with the others is bewildering. thanks for any suggestions
  • 563 Answers
Hi there
Right next to the Mainboard sits the inputboard where all your video inputs go into. This small board might need replacement.
Very cheap to have replaced.
Posted on Apr 01, 2008
DVD player-ND-861. Why has it started showing videos in black and white instead of color?
If you are using this with a cable that has just yellow for video, and red and white for audio, you may have inadvertently put the DVD player into the progressive scan mode. Some DVD have a button on the remote that actually says progressive scan. Find you instructions to change to composite mode versus component. If you use a five wire cable then place the DVD into the progressive scan mode.
Oct 11, 2017 | Televison & Video
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Panasonic DMR-HS2 RF out is not outputting signal CH3 CH4 off
The most likely cause of this is the unit being in progressive scan mode. In progressive mode, the composite output is disabled. If you can, connect the DVD using the component output connections. If your TV does not have component input, connect the green connector to the yellow on the TV. If the unit is in porgressive scan, you will see a garbled picture on the screen. The only way to fix this is to turn off progressive scan. The manual will tell you how to do this.
Dan
Apr 10, 2009 | Sony STR-DG510 Receiver
Conia 250 dvd player
You may have switched to progressive mode.
If you have your DVD player hooked up to your TV with anything other than composite video (single, yellow RCA cable), for example via component or HDMI, than disconnect that cable and use composite.
This may help, but only if that's really what you did, and if the DVD still sends the interlaced signal out over composite (which doesn't handle progressive).
May 14, 2008 | Televison & Video
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Composite outputs not working but component output does on dvd/vcr combo
I solved the problem. It was a flaky TV source selector that caused.
Feb 06, 2008 | Pioneer DVR-RT300 DVD Recorder/VCR
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Component Input
To save cost on this model, as with many others they are sharing the S-Video input circuits with the composite input circuits at the entry point. There is a kill switch incorporated with the S-Video jack in the set. Even if you put an external switch box to the set, the composite video will not work unless the S-Video plug is pulled. Your best solution is to get a TV set with a true multiple video input. The other alternative is to have a sat receiver with an external input for throughput feeding. Another alternative, but not as good quality as S-Video, is to use your sat receiver in the composite mode to the set, and have an external switch box to select one or the other.
Sep 17, 2005 | Panasonic CT-27SC13 27" TV
BenQ PB6100 Multimedia Projector Logo
70 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Computer Links
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
