Question about Acer AL1916W 19" LCD Monitor
I was given a 2003 Acer AL1916 monitor and came home and hooked it up to my old Compaq presario computer. The screen is fine but the audio is barely audible. I had speakers hooked to the side of my old monitor and I am using the speakers the other people used with the Acer which are desktop. There is no where to hook them to the monitor. Any suggestions?
    Scholar:
  • 68 Answers
The speakers are not supposed to plug into the monitor, they will plug into the speaker jack on the back of your computer (usually a green plug or it will have a picture of a speaker next to it)
Hope this helps
Good Luck!
Posted on Dec 09, 2008
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
MONITOR PROBLEM
This may not be a Monitor problem. So if you can try to get to test monitor on another computer. Check carefully the data cable to ensure there are no bent pins. If it turnout to be a monitor problem then at only 6 months -Acer should replace it. If the monitor works - you should have the graphics card on the computer checked out. If you feel you can do this - and you can- basic checks come back as another request.
Jun 06, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
