Question about Kodak Easyshare M753 Digital Camera
Broken usb port
I have a kodak easyshare m753 camera. i put the usb cord into the port and the whole thing got pushed into the camera. is there anyway to fix it myself or another way of getting the pictures onto my computer?
  • 477 Answers
The only way to get your pictures off the camera and on to your computer is to get a sd card reader off ebay they are pretty cheap there or get one from radio shack. plug this into the usb port put your card in it and wala you have access through my computer to get your pictures. hope this helps if you need any more help cantact me at digitalcamrepair.com.
Posted on Dec 09, 2008
Where on my computer do I plug in a usb cable from my easyshare M753 camera and which end of the cable is which
Hi, You plug the cable into the USB port if you have one...that will be the larger end and the samller end goes into the camera...
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
Apr 30, 2011 | Kodak Easyshare M753 Digital Camera
Can i charge it on my netbook?
Yes, assuming the netbook's USB ports put out enough current to do so. Charging a battery requires more current than some USB ports can handle. Go ahead and try it, you're not going to damage anything by doing so. If it works, it works. If it doesn't, it doesn't.
Mar 17, 2011 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Screen broken, what to do now???
If Out of Warranty repair: 48 pounds
Please contact KODAK in order to arrange a repair:
The Contact to KODAK can be found through this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 20, 2009 | Kodak Easyshare M753 Digital Camera
USb Cable for my Kodak Easy Share M753 wont connect to my camera.
When you dropped it, it should not cause any major damage to the physical slots unless it is totally broken etc.
As to the USB cable, you should be using this type:
Aug 25, 2009 | Kodak Easyshare M753 Digital Camera
Can not charge my kodak i think its my usb cable.
If trying to charge using USB through a computer, you have to have the computer on, booted up, and running! The only other thing to try if that is not the problem is to replace the USB line you use, checking plug ends for damage. Good Luck!
Dec 16, 2008 | Kodak Easyshare M753 Digital Camera
Cant get camera kodak m753 to charge
It appears that your problem lies with the main board their are two small fuses on the main board that can cause this problem. changing the main board is most likey your best bet repair on this can be around 65.00 and up depending on where you get it fixed.
Dec 02, 2008 | Kodak Easyshare M753 Digital Camera
How do I tranfer a picture from the Kodak EasyShare software back to the M753 digital camera?
I just take the disk and put into the computer slot designated for that size of camera disk and export from the kodak program back to the disk and put back into my camera. I do not have my dock hooked at this time into my cpu. so I use my little disk by moving it back and forth, I have too much hooked to my cpu,. You can buy and adapter that attached to a port and is use for 3 different sized memory cards. Works great.
Sep 23, 2008 | Kodak Easyshare M753 Digital Camera
Lost my cords during a move
753 has a special mini usb cable only from kodak-buy a 20.00 sd memory card reader and use that to download-they work great!
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Not charging
does the charging light come on. if it does the battery is charging is it plugged into a usb hub if so the camera will not charge. it has to be connect to the computers usb port directly.also some computers have a built in usb hub witch cause this to happen. try using the usb plugs in the back they are diffrent addresses. also check you cable for any damage. I thing about USB is they are touchy pains. I had to fully reload my computer twice because of a USB problem best thing to do is get a seperate charger for your battery and a memory card reader to transfer your pictures.
Jan 11, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
64 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
