Question about Dell Latitude C640 Notebook
Error at start up
Suring start up i am getting this message "invalid configuration file, please run start up" after a few minutes i get this message "no physical harddrive found" in the bios it does not detect the hard drive , i fear that my hardd drive has gone bad. Any expertise on this , anyone ??
  • 1 more comment
  • BLue BLue Feb 26, 2007
    i have already replaced the hard drive, i put another used harddrive to load windows but it gave the same error. If its a software problem then what kind is it ??
    Thanks
  • BLue BLue Feb 27, 2007
    Let me be clear with my original hard drive i am getting this error "invalid configuration file, please run start up" . i put another working hard drive and i got the same error . i am not sure if something is worong with the harddrive or the software
  • BLue BLue Feb 28, 2007
    thanks ....i think i should get a brand new hard drive and then try to install windows on it ...hopefully it will work.
  • 624 Answers
Blues, The first thing I would try is to remove and reseat the hard drive. With the laptop oriented with the cover latch towards you the hard drive is on the left of the laptop towards the front end. -Flip the laptop over and locate the hard drive carrier door. -There is one screw holding the drive in place, remove it. - Lift the hard drive door up until you hear a click. -Slide the hard drive out of the computer. -Reinsert the drive and push the hard drive until it is fully seated in the hard drive bay. -Reinstall the retention screw. If that doesn?t work then you either have software corruption problems or hardware failure or both. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 25, 2007
  • tomj23 Feb 27, 2007
    If I understand you correctly you?ve installed another used hard drive and you received an error saying no hard drive found. Are you getting this error while going through the Windows install routine using an install CD?
  • tomj23 Feb 28, 2007
    From what you?ve told me I?m not sure yet. Assuming the 2nd hard drive is blank or can be reformatted (and is still in the laptop) try this and we should be able to start heading in the right direction:
    -Place your Windows installation CD in your CD drive.
    -Boot to the CD drive and go through the installation process.
    -At some point early in the installation process the program will inspect your computer for a functional hard drive to install Windows. If it doesn?t find one it will tell you in no uncertain terms. That will point us in the direction of an incorrectly configured BIOS or perhaps some malfunctioning electronics. Let me know what you find out and we'll pickup from there.
What does the error message - 49.4C02 - mean?
49 errors are often caused by the printer receiving commands it does not understand. Sometimes hardware failures but not often. To determine hardware or software, turn the printer off. Unplug any network or USB cables attached and turn printer on. If it will come to ready with no cables attached, then likely you have a print job that is causing problems. This can be fixed by installing the latest firmware from HP.com. Download the Easy Firmware Update Utility version. To install this update you need to have the printer connected to the computer, so check the print queues to make sure that there are no print jobs pending, delete them if there are. Plug the network or USB cable back in. Wait a couple of minutes to make sure that the 49 error does not come back. If printer stays on ready, run the upgrade utility and your problems should be gone. If it is a hardware issue then a different set of trouble shooting steps applies. Post back if this does not fix your problem.
Aug 15, 2014 | HP CP3525DN Color LaserJet Printer
Installed The Print Shop 2.0 Deluxe on my Windows XP, SP3 & seemed to install fine. Won't run, gives me error message - "The configuration file is missing or invalid; you may have to repair...
Hello there, At first, go to start menu, all programs, accessories, system tools, open System Restore. Restore your system to restore point created before installing The Print Shop. After that, try to install it again. Otherwise, you can try to install it from different CD, or installation file. Sincerely, Steve TM
May 28, 2011 | Computers & Internet
Please run setup invalid configuration information
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong.
If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery.
If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Dell INSPIRON 6000 CENTRINO...
Hii, I lately bought the Samsung Chat 335. When you start the phone for the first time, you receive a few messages with configurations for mobile internet etc. Whenever I try to install the mobile...
I lately bought the Samsung Chat 335. When you start the phone for the first time, you receive a few messages with configurations for mobile internet etc. Whenever I try to install the mobile internet it says: "invalid network-PIN". What's wrong with it?
thank you!
Apr 17, 2011 | Cell Phones
I downloaded this software yesterday but it didn't run on my PC. when i installed, this message appeared on the screen & stop the process of installation. " Error 1904. Module...
Well I would remove all software to that hardware being the TV card. Reboot the pc see if the error regenerates. If not then I would reload the newest version off the manufactures site. As well I would go into the msconfig and tell it not to run on bootup.
Aug 13, 2010 | Computers & Internet
Tray error invalid config
Message:
TRAY ERROR INVALID CONFIG
What this message means:
The printer detects an incorrect configuration of the trays.
What you can do:
Turn off the printer. Set the trays in the proper configuration again.
See "Installing the Optional Tray Module" in the manual book.
Please find below a link to give you a brief idea on the process. Exact details can be viwewed from the manual only:
http://www.csudh.edu/CLASS/voffice/dell3100printer/Contents/section08.html#513263
Sep 10, 2009 | Office Equipment & Supplies
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Gateway solo 9550 invalid configuration error when booting
Please look to see what error you're getting. You are getting one and it will tell you the problem.
May 29, 2009 | Gateway Solo 9550 Notebook
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
My Toshiba Laptop
click Start>>Run>> (type)Msconfig>>Click ok
System configuration utility window will open up
U will see few tabs at the top like General,Startup
Click on startup tab
At the bottom click disable all>>Close>>It will ask for restart
Restart the computer
when the computer restarts you will get the message
You have used the system configuration utility
Check the box at the bottom Do not Show this Message Again and click ok
Now you wont see the icons that use to load up on the right bottom of your system,however they have not been deleted just hidden,if you want to access any of those programmes that use to appear before
Click start>>All Programmes>>and clik the application you need to open.
May 25, 2008 | Toshiba Satellite A105 Notebook
Dell Latitude C640 Notebook Logo
69 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
