Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
I have the same problem. Please advise how to fix it.
My sony kp-51ws510 has started having color issues,the blues and yellows and greens are not lined up and the picture sometimes looks like I have a tracking issue if I were to be playing a VCR. I tried the alignment, but it did not help. I do not have any lights flashing or anything.
Is the board bad? Is it worth trying to fix or just get a new TV?
  • Anonymous Dec 12, 2008
    My sony kp-51ws510 has started having color issues,the blues and yellows and greens are not lined up and the picture sometimes looks like I have a tracking issue and double vision. I do not have any lights flashing or anything.
My sony kp-51ws510 is out of alignment and the colors are in 3d
Posted on Aug 04, 2010
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Posted on Aug 07, 2009
The picture is is now in pink
If Sony KP-51ws510 it is an common issue with the picture tubes but there may be a simple way to adjust something in the set to correct this--these had problems with the 3 picture tubes where it can go to excessive red, green or blue.
Confirm model and issue and I will assist.
It only requires a screwdriver and the back does not have to be removed in this case.
Mar 20, 2012 | Sony KP-51WS510 51" Rear Projection...
My Sony KP-51WS510 is out of color focus. The blues and yellows are separating. I know there are three color bulbs that work together to create all the colors. Could the bulbs be out of alignment from...
Convergence ICs and CK all Pico Fuses around ICs they will look like resistors but will be Green or Yellow 5amp, 6amp, 7amp Fuses. Big Black ICs they will have the PN# on them
ICs STK392-110 use 120s Mats 1-800-628-1118
TV Repair Shop $255.00
Oct 21, 2010 | Sony KP-51WS510 51" Rear Projection...
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Color on tv not maching
Sounds like convergence issue....Can you describe " colors
go nuts"..........If red green or blue separate, replace STK392 IC's
located on large heat sinks.........T.
Oct 29, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
