Question about Sony VAIO A260 Notebook
Sony A260 touch pad does not work
Data bus that lies between the RAM and the bottom of the keyboard got snapped while trying to upgrade the RAM. This is the cable that connects touch pad and other LEDs on the front panel. Is it possible to buy this part and replace on my own? If so, where would i get the part number?
My keyboard and touch pad compaq presario cq40 not working i try to reinstall keyboard and touch pad but it still not working ,and then i remove to put new keyboard but it still not working at all..... so...
You tried to reinstall the keyboard and touchpad hardware parts? Have you had ANY damage? Spill? OS upgrade? If you replaced the hardware is the ribbon cables connect properly?
Apr 19, 2013 | Compaq Presario CQ40 Series Laptop Charger...
I have an HP NetServer E800 when i power on it beeps 4 times then no signal on screen???
Code Beeps POST Routine Description
16h 1-2-2-3 BIOS ROM checksum
20h 1-3-1-1 Test DRAM refresh
22h 1-3-1-3 Test 8742 Keyboard Controller
2Ch 1-3-4-1 RAM failure on address line xxxx*
2Eh 1-3-4-3 RAM failure on data bits xxxx* of low byte of memory bus
46h 2-1-2-3 Check ROM copyright notice
58h 2-2-3-1 Test for unexpected interrupts
98h 1-2 Search for option ROMs. One long, two short beeps on checksum failure.
B4h 1 One short beep before boot
Jul 29, 2010 | HP NetServer E800
Keyboard does'nt work
Step1:Check whether the Keyboard and Touch pad BUS Cable connected to the Motherboard.
Step2:Clean and Re fix the BUS Cable.
Step3:If Still it is not working Circuit Board need to be replaced.
Pharthiphan
Nov 06, 2009 | Compaq Presario 700 470024-192 Notebook
How to put extra memory in Lenovo T60 laptop
Ok the RAM location is actually underneath the touch pad on the top of your keyboard. However, to get to the memory area where you can add/remove RAM cards you need to do the following:
STEP 1) On the botton the latop you should see 4 screws that have a "memory chip" ICON. These are the 4 screws you want to take out. (important note: my T60 has 4 screws with this icon, yours might have 5). Please the screws somewhere secure so they are not lost.
STEP 2) After you take out the screws noted in step 1. Flip your laptop and open it up as if you were going to type something.
On each side just below the keys pull up gently and the botton portion that has the touch pad will come up. You want to pull it back towards you. You won't be able to complete remove it away from the laptop, because there's a ribbon cable connecting the touch pad. So just move the piece back toward you out of the way (in essence peeling it back toward you).
STEP 3) You should now see the RAM card(s) they will have a bracket mechanism on each side of the RAM card, push them outward to unlock the RAM card (if your removing.
STEP 4) If your ADDING RAM. Evaluate if you need to remove existing cards or not. To install RAM you insert the new card in the slot, then push it down and it should snap int place.
STEP 5) Place the touch pad plate back into position and push it to snap down.
STEP 5) Close laptop cover, flip over and insert the screws back into their positions.
Jun 17, 2008 | Lenovo Thinkpad T60 Notebook
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
Touch pad not working
Only easy solution is to use a usb mouse instead :(
Touchpad can be replaced but its part of the actual casing so would be expensive to replace. :(
Dec 26, 2007 | Sony VAIO A260 Notebook
Keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Nov 19, 2007 | Dell Latitude D800 Notebook
Vaio VGN-A260 dvd drive replacement
On my Sony 770 there were 5 screws under the drive and it slid right out.
Nov 18, 2007 | Sony VAIO A260 Notebook
Sony VAIO A260 Notebook Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
