Question about Baby Lock Esante
Buttonhole lever The buttonhole lever doesn't seem to be sensing the "end" of the buttonhole. The machine just keeps sewing the left side of the buttonhole without reversing to sew the other side. The lever even pushes on the buttonhole foot sliding it back farther. Can I fix this problem?
  • 1 more comment
  • JanieH Oct 11, 2008
    I had the same prob, while you are sewing the buttonhole the foot will push against the lever that you had to pull down and that tells the machine what to do next.
  • Anonymous Mar 19, 2014
    How do I lower the buttonhole lever
    how do I lower buttonhole lever
    Genius:
  • 1,074 Answers
Is your equipment electronics or mechanical kindly answer the question then i will be able to help you
Posted on Mar 19, 2007
  • 4 Answers
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
It does not have 4 steps to do a button hole and will only stitch on the right hand side when I put it on the button stitch. How do I do the end pieces and the left hand side?
You can perform all the steps of a buttonhole without the buttonhole option (ask how sewists used to do it before sewing machines offered the buttonhole option). You'll just need a machine that can zig-zag.
How to sew buttonhole with an old machine
Making Buttonholes Without Special Feet
There are a lot of web sites and tutorial videos available.
Jan 22, 2016 | Sewing Machines
How do I fix a buttonhole stitch that is stalled with a 6l code?
normally with the a sewing machine won't do a buttonhole stitch, unless the buttonhole lever is pulled down,, but if your buttonhole lever is down, then there could be something wrong with a gear or cam inside of the machine.
Jun 14, 2015 | Sewing Machines
How can I make a buttonhole that's bigger than my buttonhole foot will allow
Measure the button, mark the size of hole you want with a pin at each end. sew 6 full width very close zigzag stitches at one end ending on left side , then sew down to the other end with needle in left position with #2 width stitches, at other end again sew 6 full width zigzag stitches finishing on right side, turn work right around and sew back to other end again with #2 width stitches.
you should now have a rectangle of very close stitches with a very narrow gap between them down the middle. carefully cut between the stitches and you have a button hole.
Feb 25, 2014 | Sewing Machines
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Jan 30, 2013 | Husqvarna Sewing Machines
Machine only sews one side of a buttonhole
your machine may have a button hole lever that has to be pulled
down before sewing, it should be on the left hand side of the needle
if that doesn't help then the machine may need to be checked
Aug 25, 2012 | Janome Memory Craft 4900QC Mechanical...
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Sewing Machines Logo
375 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
