Home | Philips | 21PT4475 TV | Picture is cut off at ...
Philips 21PT4475 TV
Problem for Philips 21PT4475 TV
Picture is cut off at top and bottom
By bickford76 on Dec 09, 2008
The picture seems to be to big. It is cut off at top and bottom. I have tried all the different format settings and it is teh same on all of them. I tried to reset all AV settings and it doesntg do anything. TV is a 42 inch Phillips flat screen less than 1 yesr old
Solution #1
posted on Dec 09, 2008
Somewhat Helpful)
Shuttle83
Rank: Guru  Philips Expert
Rating: 85%, 980 votes
Hello This is an indication that your vertical output stage is beginning to malfunction. It could be the vertical output IC or the vertical coupling capacitor. I would suggest using the schematic and an oscilloscope to determine if the signal is correct. You may have to replace the IC or the capacitor.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Was this helpful?
Yes
No
Popular Solutions for Philips 21PT4475 TV
Questions and Unsolved Problems for Philips 21PT4475 TV
Do you recommend Philips 21PT4475 TV?
Answer
Answer
Blank raster with flyback lines on a Philips 21PT135A TV. Chassis type Anubis A AC. The sound is OK.... (More)
Answer
i have purchased aa sony tv [model no kv-bm212m10] from a hotel and cannot get into the tune... (More)
Answer
How can We get the service menu(correct sound) 21Pt2115, 21PT2325, 21PT3324?
Answer
onida , LG, SUMSUNG,PHILIPS
Answer
How to remove Hotel mode and have normal mode
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 21PT4475 TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
