Question about Brother GX-6750 Typewriter
How do I reset the keys
I have had to reset the typewriter before but I forgot what to do...Help! They keys are off and I know that there is a "code" to fix it.
    Scholar:
  • 183 Answers
When you turn the machine off for a few secounds and then turn it back on it automatically resets. if it doesn't, leave it off for longer. if it still doesn't work make sure the ribbon and correction tape are installed correctly and arn't interferring with the printwheel
Posted on Dec 18, 2008
Beeper quits working comes back after few days then keyboard sometimes locks up?
Don't know what kind of machine it is, but most will have a clear and reset. Swintec turn off hold the MR key turn on. Brothers depress the code key hit the reset (Q) key and release.
May 08, 2014 | Office Equipment & Supplies
Cant reset margin lines help!
Space or backspace to the margin you wish to change touch the margin release key, space to the location yuo want press the R or L margin key, on some T/W's the code or alt key may have to be used to access these functions.
DickyO
Mar 23, 2009 | Office Equipment & Supplies
In need of a brother GX-6750 typewriter owners manuel please help
First press the Code key and Q simultaneously. That will reset the wheel position. If it clicks or otherwise fails to type properly, pull out the wheel and inspect it. One or more of the types may be bent. In that case, the wheel needs to be replaced. Good luck finding the part.
Feb 03, 2009 | Brother GX-6750 Typewriter
WPT-61
there is a key that has BOLD printed under the letter on the key, or it may be printed above the top keys on the keyboard, hold down the code key and hit the key under where it says BOLD, or the key that has it on it. to take it off, do the same thing
Jan 08, 2009 | Nakajima AE-830 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Smith corona typewriter settings
I am not sure but I think you the code key while pressing the format key then make the selection in the display.
Jun 16, 2008 | Office Equipment & Supplies
Code 120
Tou can try pressing and holding the code key, press and hold the "L" key, release code type 001, release "L" key. Your keyboard may be bad this will select USA keyboard.
Good luck
DickyO
Mar 28, 2008 | Lexmark Wheelwriter 3500 Typewriter
I need to reset the left margin.
Use the code key..hold down while you press the left margin set key...if you have to go beyond the left margin press the mar rel key and backspace to the spot you want the margin to be. Then proceed using the code key and left margin set . On some typewriters turning them off resets all th margins..some it does not
Jan 01, 2008 | Olympia Startype 3 Typewriter
IBM wheelwriter 1500 by lexmark
Press and hold the code key and the label key this should reset it.
DickyO
Nov 30, 2007 | Lexmark Wheelwriter 3000 Typewriter
Royal-Adler Stellite 40 mistyping
The printwheel has lost it's home position. Release the lever holding the printwheel, remove it and re-install it. Push the lever toward the platen to lock it in. Turn the typewriter on. The printwheel should spin, the carriage should move to the left and the come back to the left margin. You should be OK after that. Let me know if it helps or not Ed
May 30, 2007 | Royal Satellite 40 Typewriter
Brother GX-6750 Typewriter Logo
98 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
