Question about Your One Source 100 Amp Main Lug Load Center
Two circuits in panel inoperative
I just installed a new QOC20U100F panel & the power surges (lights flicker) with the breaker in #7 & #19. When I move the breaker (hot attached) to any other location it works fine. Does this mean the panel is defective? Thanks
  • davesyellow8 Dec 09, 2008
    Thank you for the quick response! I'll follow your advice as I'm sure you're right. That was my first thought also & spent a couple hours working back to the panel.
    Sergeant:
  • 359 Answers
Not likely check the neutrals on those circuits the chance that 7&19 are bad and everthing in between is good is almost impossible. i would check the wires very close and also inspect the neutral buss connections both main connections and circuit connections
Posted on Dec 09, 2008
Is there a service bulletin for a Pontiac G5 for electrical issues?
their are 7 recalls on the 07 none are for an electrical problem with lighting system
http://www.pontiacproblems.com/recalls/G5/2007 and the following tsb from march 2010 is for flickering lights
  • TSB #PIC-5073B NHTSA ID #10034409
    • Date Announced: MARCH 01 2010
    • Additional Info: How to Fix
    Summary: CHEVROLET/PONTIAC: VARIOUS ELECTRICAL CONCERNS. SIR LIGHT, IP LIGHTS FLICKER/INOPERATIVE, PARKING LAMPS FLICKER/INOPERATIVE, TAIL LAMP DIM/INOPERATIVE, TRUNK OPEN LIGHT, RADIO INOPERATIVE DOOR LOCK INOPERATIVE, NO START, NO CRANK. POSSIB
    More Information »
ELECTRICAL SYSTEM:WIRING
  • TSB #PI-0817 NHTSA ID #10047261
    • Date Announced: SEPTEMBER 01 2012
    Summary: CHEVROLET/PONTIAC/SATURN: ENGINE FAILS TO START AFTER ENGINE CRANKS DUE TO FUEL PUMP WIRE HARNESS CONNECTOR NEEDS REPLACING, WITHOUT REPLACING FUEL PUMP COVER ASSEMBLY (FUEL PUMP FLANGE). MODEL 2007-2010 COBALT, G5, ION. *PE
    More Information »
ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
  • TSB #PIC-4578 NHTSA ID #10022806
    • Date Announced: JUNE 01 2011
    Summary: EPS/STR WHEEL CONTROL FUSE (#19) OPEN. *KB UPDATED 10/04/07. *NJ UPDATED 8/7/09. *PE UPDATED 8/1/11. *PE
    More Information »
  • TSB #PIC3385 NHTSA ID #10020916
    • Date Announced: FEBRUARY 01 2008
    Summary: REPEATED PARK LPS FUSE OPEN. *KB (ADDITIONAL INFORMATION) UPDATED 4/1/08. *NJ
2007 Pontiac G5 Recalls CarComplaints com
Sep 21, 2015 | 2007 Pontiac G5 Gt Coupe
Blackout yesterday now when try to use all lights flicker and constant alarm sounds
Try resetting the circuit breakers. Ugly things happen when power surges back in, but perhaps this may help.
Mar 03, 2015 | Fisher and Paykel Washing Machines
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
Jenn air svd46800 not working
I'd be on the hunt for a burned fuse I could replace, on those two circuit panels. If no fuse(s) can be found, I would be sad to think the circuit board itself got fried, and new ones can be goofy expensive, so here's to you finding a burned fuse!!
Jan 14, 2014 | Jenn-Air Ovens
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
Can i replace the main (100 amp) is a sq d QOC20u100F panel with a 200 amp main--i will up grade meter socket and entrance cable to 200 amps cwalker
First the part number QOC20U100F is a flush mount panel cover. The panel you have is most likely a :QO116M100. No you cannot replace the breaker as the bus in the panel is only rated for 100A. In addition I believe this is a 20CKT panel. If you're gonig to a 200A service you'd probably want more spaces than that. Home Depot and Lowes both carry 200A panels with starter set of breakers at reasonable price. The QO panels are a bit better than the Homeline
Here is a link to manual for their panels. :
http://static.schneider-electric.us/assets/DIGEST/load-centers.pdf
Aug 21, 2010 | Your One Source 100 Amp Main Lug Load...
Have a 2004 taurus.no owners manual. cig lighter fuse blew,dont know which one it is.
Fuses, Switches, Circuit Breakers And Relays Most vehicles use one or more fuse panels. This one is located on the driver’s side kick panel tcca6p01.jpg
It is possible for large surges of current to pass through the electrical system of your vehicle. If this surge of current were to reach the load in the circuit, this surge could burn it out or cause severe damage to the vehicle’s electrical system. It can overload the wiring, causing the harness to get hot and melt the insulation. To protect vehicle wiring, fuses, circuit breakers and/or fusible links are typically installed into the power supply wires throughout the electrical system. These items are nothing more than a built-in weak spot in the system. When an excessive amount of current flows through a circuit it causes an increase in heat throughout the wiring. Fuses and circuit breakers are designed as the weak link in the system and will disconnect the circuit to prevent damage to the components contained within that circuit. Components are equipped with connectors so they may be replaced in situations where they were damaged due to a power surge.
The following are descriptions as to how fuses and circuit breakers protect the electrical system:
  • Fuse- A fuse is a weak link in the system designed to create an open circuit when the amperage flowing through that circuit exceeds the limits of the fuse. As the amperage increases, the conductor within the fuse heats up and eventually melts and breaks apart. This open circuit interrupts the flow of current and protects the components in the circuit.
  • Circuit Breaker- A circuit breaker is a "self-repairing" fuse. It will open the circuit in the same fashion as a fuse. The surge creates heat the same way that a fuse is affected. When the surge subsides and the circuit cools down, the circuit breaker will reset and allow current to flow through the circuit. Typically circuit breakers do not need to be replaced.
  • Fusible Link- A fusible link (fuse link or main link) is a short length of special, high temperature insulated wire that acts as a fuse. When an excessive electrical current passes through a fusible link, the thin gauge wire inside the link melts, creating an open to protect the circuit. To repair the circuit, the link must be replaced. Some newer type fusible links are housed in plug-in modules, which are simply replaced like a fuse, while older type fusible links must be cut and spliced if they melt
CAUTION
Always replace fuses, circuit breakers and fusible links with identically rated components. Under no circumstances should a protection device of higher or lower amperage rating be substituted.
I would get a fuse tester that can test fuses while still installed and powered up. It will light if the fuse is blown when applied to the two tabs that are exposed on fuses that are installed in your Ford product.
Check the fuse box under the dash on the driver's side, and check to see if there are any fuses under the hood.
If you don't have the tool, try to look for stickers or download the manual from ford.com.
http://www.ford.com/owner-services/customer-support
Jul 31, 2010 | 2004 Ford Taurus
Home electrical problem: Lights on one circuit do not work. They were flickering for a while, then went off completely. I replaced the circuit breaker in the panel, and tightened up all the ground wir
Sounds like a bad connection. First thing is to check any wiring that you had installed or changed.
Is the home wiring copper or aluminum?
If you know that the circuit breaker is working (check with volt meter) then you have to check all the splices on that circuit. The bad splice will be the first light on the circuit
Apr 15, 2009 | Kitchen Appliances - Others
Replacement 15A circuit breaker does not work
If the light is a flouresent light more than likely the ballast is bad. Very simple to replace but make sure power is of..Very common problem.
Feb 16, 2009 | General Electric 20 Amp, 1 Pole Thick Type...
Your One Source 100 Amp Main Lug Load Center Logo
77 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
