Question about Nintendo DS Lite Console
Erratic power on and off
I had my DS for over a year now, and about a month ago i accidently bent the prongs on my AC adaptor. After straightening them, i proceeded with charging the DS. A week later, the power turns on and off irregularily, usually when i'm playing! Now the power switch doesnt even turn it on or off anymore. i blame the bent adaptor, but those around me disagree. Any suggestions?
  • Anonymous Dec 09, 2008
    I appear to have a simillar problem! My DS Lite seemingly turns itself off, when I'm playing, for no apparent reason! Its really annoying, I have to play on my old DS. Any explanation, and/or how to fix it would be MUCH appreciated!
  • john savage May 11, 2010
    Thats unusual as it would indicate a permanent connection on the main board??? basically making the switch redundant. Have you tried another new supply or battery..I suggest you go for the cheapest option 1st...check battery and how its seated.. there are 2 prongs on in the battery compartment they need to be making contiuous connection with the battery. failing that and you feel confident enough to tackle a repair then you can get advice online. Otherwise send it to a reputable repairer. I hope this has helped a little
    Scholar:
  • 168 Answers
Sometimes the connector can break loose from the board, there is very little solder holding them on and this would cause erratic behavior, everything is so small that the slightest improper connection causes big problems.
lets get you fixed up.
ninja_freak318@hotmail.com
Posted on Dec 13, 2008
Prongs have bent how do I straighten them ? The bent wen I plugged the kinect adaptor in their !!! PlEaSe HeLp
Try using a fork or thin knife to straighten them out. Be very careful and gentle though. Maybe just take them to professionals to get it fixed, before you damage it more. Long nosed pliers also might work.
Feb 24, 2013 | Video Game Consoles & Games
My ds won't read ds games, but it reads gameboy games
then u need 2 fix the prong thingys in the back the way i did it is i took the stylest across the prongs 2 straighten them uo
Dec 29, 2009 | Nintendo DS Lite Console
The internal power supply prongs are bent. How do
Thanks for using fixya..
If the prongs are bent, all you need to do is to get a pair of pliers and try to re-align them. If that is not possible, you can try to open up the power supply and directly tap the power cable into the prong's cable line (if you have an idea how to do this, go on and try it. If you have absolutely no idea how to do it, then its better to just bring your power supply to a local electrician, they can probably fix the problem in no time)
Thanks and have a nice day
- Hotratchet
Nov 03, 2009 | Dell POWER SUPPLY Power Supply
My ds lite wont read any of my games
This is a common problem.
Most of the time it is one of the little copper pins in the game slot1 that has become bent and needs to be straightened out.
Bringit to a repair shop to get sorted shouldn't cost more than €10-15.
Sep 07, 2009 | Nintendo DS Lite Console
Erratic Touchpad on Toshiba M50 Notebook
if the touchpad is working fine with the battery and if it is not working with the ac adaptor then in this case u can try with the different ac adaptor and still if it does the same thing then uninstall and resintall the toouchpad driver and restart the computer and still if it does so with the ac adaptor then u need to open the laptop chasis and then u need to fix up the power supply connector in the motherboard where the power supply from the ac adaptor is not getting the adequate response from motherboard.
Dec 21, 2008 | Toshiba Satellite M50 Notebook
DS nintendo lite
open it up and push the prongs back through- it happened with mine, but the screws have quite pain in the arse ends, so you will have to find the correct screwdriver. it looks kinda like this=
I
Aug 25, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
My Nintendo DS Lite keeps freezing. It will play for a bit then freeze. When I turn the power off then play it, but then freezes again! Any answers?
Try this as it will restore the DS to factory settings.
Remove the battery cover off the back of the unit. (One small Philips screw.)
Remove the battery.
Leave the system without the battery for 10-15 minutes.
Replace the battery.
Re-install the battery cover.
Dec 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
