Easyest way to take off
Acura Coupes and Sedans 1986-1993 Repair Guide Print Fig. Fig. 1: Disconnecting the fuel lines from the fuel filtebest way to take it off - 0900c152800494d1.jpg>
Fig. Fig. 3: Fuel filter replacement-Legend and Vigor
Fuel Filter
The recommended change interval for the fuel filter on all models is 60,000 miles under normal service. Severe service will require more frequent changing of the fuel filter.
The filter is located in the passengers side of the engine compartment.
CAUTION
Before disconnecting any fuel lines, be sure to open the gas tank filler cap to relieve any pressure in the system and wrap a shop towel around the fuel line fitting before opening. Observe all fuel handling precautions.
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
It is very important that ALL of the fuel line banjo bolt washers be replaced every time the banjo bolts are loosened. If the washers are not replaced the fuel lines will leak pressurized fuel causing the risk of fire or explosion.
best way to take it off - enlarge_tooltip.gifimages/enlarge_tooltip.gif" alt="enlarge_tooltip.gif" class="h_mi" />
