Question about Infinity 475A Car Audio Amplifier
Protect Mode Whenever it's cold my amp stays in protect mode for a while until my car heats up. It's an 06 taurus. This didn't happen until the weather got cold. It hasn't left protect mode for a few days. I know amps perform better in the cold which is why I'm confused. Maybe it's possible that the car is drawing too much power to heat the car, not leaving enough for the amp. It's not a huge amp though so I don't see why this would happen. I asked a Best Buy installer and he said he hadn't seen the problem in 10 years of installation. Any ideas?
    Genius:
  • 1,139 Answers
first I would advise you to tighten all of your ground and power connections. Then I would suggest that you expose the circuit board and start the amplifier warm up process, once the amp comes on I would use freeze spray to cool down various components in an attempt to find the component which has become thermally sensitive. Once you find the component I would suggest replacing it and the putting the cover back on the unit.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 09, 2008
Overheating gage when stop & go -2004 chevy tahoe
natural for engine temp to rise in Traffic - Until Themostat opens ) cooling fan sensor kicks on fan . But Antifreeze is not just a Cold weather item . Coolant is Absolutely Necessary for Hot Days . You must be full to recovery bottle setting of cold when checked prior to start up . Coolant for your make / model is Reddish - Pink colour and should have a reading of -25 thats negative 25 degrees the Lower the Better even - 50 .. Why ?? - 50 is 50 %% antifreeze / Coolant Concentrate MIX Gives Hot weather cooling Ability or very cold weather starting / winter HEAT .
Mar 14, 2014 | 2004 Chevrolet Tahoe
1991 f 250 when starting during cold weather starter sticks to the run postion and ignition i can turn back and forth and truck will not shut off until starter burns out
IT sounds to me like the solenoid is sticking. Follow the large wire up from where it bolts onto stater and the next thing that wire is bolted to is the solenoid.
Nov 26, 2013 | 1991 Ford F250
Car never reaches operating temperature (cold weather) thus little to no heat inside
change the thermostat, sounds like it could stuck open and wont allow the engine reach operating temp, also test the constant control relay module located to the right of the battery as your facing the front of the car, also test coolant temp switch it might be defective and producing a high voltage that would cause the fans to constantly operate no matter the temp. Hope this helps
Nov 25, 2012 | 2003 Hyundai Tiburon
What should my 2004 ford taurus coil pack ohm out ?
\ You either use an oscilloscope,a scan tool in Mode #06 to check for misfire counts on a road test or just replace the coil or walk a new one until you get the bad cylinder The coils only break down when hot & car driven, unless really bad & then the Mode #06 will work on most of them Codes are not always correct on a ford & you get all sorts of unrelated ones Always start all vehicle work by checking battery voltage first & make sure that it holds when key is off
Nov 12, 2012 | 1999 Ford Ranger SuperCab
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Lightning Audio b2.3000.4 is in protect mode. i removed all speaks and conected the amp directly to the battery and it still stays in protect mode. what can i do to fix this problem?
  • Only a select few things can cause protect mode with the battery only connected.
  • An installation issue. Check the Power, Ground and Remote wires. Make sure non are shorting from one terminal to the other.
  • It is still overheated and has not had time to cool down from being in thermal protect mode.
  • The amp itself is touching metal. You always want something non conductive between the amp and where it is mounted, this includes the screws being used to anchor the amp. They should never touch the metal in the car either.
  • The final thing that can cause an amp to go into protect mode while only hooked to the battery is the amp itself is malfunctioning and or defective. You can try opening the amp and look for any black spots on the circuit board where an electrical component might have smoked up or blown and replace that part.
Regards, Tony
May 21, 2011 | Lightning Audio B2.300.4 Car Audio...
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
Its in protect mode and wont go back to normal
disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
Infinity 475A Car Audio Amplifier Logo
208 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
