Question about Garden
Not starting leak thru the carburator the machine is new and is been used 2 times only
Ihave a 2000 washer when i tilt it to move it the eng chokes and shuts off
Posted on Jul 30, 2009
    Sergeant:
  • 359 Answers
Could be stuck float tap on carb with a small piece of wood and see if gas flow stops , if so add fuel conditioner and try again
Posted on Dec 09, 2008
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
Tip
Precautions to take when storing 2 cycle lawn equipment
Any time a weed wacker, chain saw, snowblower, leaf blower, or any 2 cycle machine must be stored for a period of time exceeding 6 months the gasoline must be removed completely from the gas tank and carburator. To do this simply run the engine until it runs out of gas then proceed to choke the carburetor and restart until no start up ocurrs this removes all fuel preventing the carburator from gumming up. This will allow you to store the unit for long periods of time without the worry of having to disassemble the carb. and clean next time it must be used.
on Dec 02, 2009 | Garden
Carburator leaks gas when cycle is started or running from what looks like vent hose?
Sounds to me like your float valve is obstructed by some debris. This is causing it to stay open and leak fuel. Better it leaks to your vent hose than it leaks in your engine and contaminates your oil.
You need a proper carb cleaning. Not some run in the gas tank sh*t. If the tank wasn't full when parked, chances are there is rust in the fuel system to get this out you need to disassemble the carburetor and thoroughly clean it.
Try not to ride the bike til you do this. It's a fire hazard.
Oct 08, 2012 | 2005 Honda VT 600 C Shadow
Petrol Car Engine OFF when Press Escilator
Have you checked the timing? It might be too advanced. I would try to retard it just a little. I would also check for vacuum leaks in any of the hoses going to the carburetor or the distributor.
Apr 22, 2017 | Maruti Cars & Trucks
Esteem carburator problem
have checked if the power comes to the solenoid is powerful or do you have before solenoid any broken wires inside the wiring cover and drops the currency? Measure the power by using an ohmmeter.
Sep 10, 2012 | Cars & Trucks
Hi, i just swapped my elec flymo for a briggs and stratton 35 lawn mower, however when ever i start it it coughs and splutters and wont run for more then 30 secs and is also spitting out oil from exhaust....
if the motor has been on its side the oil has runs out thru the muffler and air filter. briggs are famous for doing that. let it sit overnight and remove the air cleaner and you see is fill of oil. next day take the spark plug and clean it and check the gap then put it back, take carburator cleaner and spray some inside the carburator, check the oil level and start.if it wont start then is time to clean carburator. the air filter if is wet in oil and is the dry type. get a new one.
Feb 08, 2011 | Briggs & Stratton Garden
My B40 is not pumping water through, and has been used twice.......Help please........ I purchased it online off of ebay......cannot return, but would like it fixed
mcdevito75 here, your coffee maker may need cleaning, with a clean or new paper filter in the machine, fill the resovoir with WHITE VINEGAR and let it cycle thru 3 times, 1/2 way thru the either 3rd or 4th time, stop 1/2 way thru shut machine off for 30 minutes, then resume, Now cycle plain water thru the machine 3--4 times to clean out the vinegar. If this doesn"t help, see any appliance repair outlet in your area, the pump could be bad.
Jul 11, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
