Dell Inspiron Mini 10 Notebook Logo
Joe Labriola Posted on Jul 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My usb ports don't work on my dell mini 10
buda2832
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Jul 08, 2012
buda2832
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
22629
Points
156
Check to see if they are disabled in the BIOS, if they are turn them on, next check the device manager to see if they are present in there, if not download the drivers for them from dell's web site, if they are there check if they are disabled in the device manager, if so enable them. you can also change the power settings for them in the device manager by click in the box for power management as after 10min of no activity the power down which can cause some devices attached to lose communication.
3 Related Answers
Anonymous
  • 3940 Answers
  • Posted on Aug 27, 2009
SOURCE: install printer to dell inspiron mini with no cd drive
Download the printer driver from HP.COM
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=psc+1310&submit=Go+%BB
Anonymous
  • 689 Answers
  • Posted on Jul 15, 2011
SOURCE: I DO NOT HAVE THE
A good idean anyway is to have an external cd/dvd drive plugged in via usb.
You can then install whatever you like and chop and change systems if you like.
First goto your manufacturers site and find the list of compatable branded external drive,this is the only way to recover your systen in your situation.
General Systems Consulting
  • 5051 Answers
  • Posted on May 24, 2012
SOURCE: dell 1420 the twoon touch pad don't respond and the usb ports don't respond so i cannot connect a mouse neither can use the touch pad buttons I am dead on the water help!
LOL, didn't you know windows 7 was just a tad bit better than vista? Why do you think microsoft will be coming out with windows 8 in the coming months by the fall of this year. They keep trying to get it right.
Go to Dell's site and see if there are Window's 7 drivers for your model. If not, try downloading and installing the Windows Vista drivers. Right now, you might not have a driver or a good driver.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers and the Chipset (which has the usb ports).
1helpful
Why don't my Dell 600m USB ports work?
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/inspiron-600m
Look for any drivers missing, in the device manager.
You will probably need, the chipset driver, to make the usb port work.
You will also need service pack 1, to support the usb function.
Good luck
1helpful
My merkury innovations mini usb mouse is no longer working
usb mice don't last long it may say 5-10 years or more but they don't and you may have to plug it in a diff. usb port if you have one
Did a windows xp recovery now I don't have any drivers installed I have the cd but it will not read it.
Hello
XP usually loads usb drivers and some ethernet drivers.
If you have access to another computer copy the drivers onto a flash drive and try to install them from it.
If you have internet access with the mini 10 you can download them from dell support.
Hope this helps and good luck.
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
1helpful
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
2helpful
Disk read error when i turn my dell mini 10 on
This usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
I can't installed video controller in my dell inspiron mini 10 (1018) notpad.can u tell my how to installed video controller driver.
go to dell.com under support & Drivers !
Choose the exact model for your Dell
and then you will get a working driver!
3answers
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
