Question about EXPOBAR Office Control Espresso Machine
Expobar espresso machine not siphoning water
We have and expobar machine that I attempted to run through the cleaning cycle (detergent in the non-fenstrated cup for the handle.) Initially it blew the breaker, but now I can't get it to brew or run the cleaning cycle. Just before all of this I changed the water in the resevoir (it had been sitting.) It looks like there is air in the lines. Is this normal? Is this a problem, or is there somthing else going on? Thank you for your time.
matt
  • petriemd Dec 09, 2008
    Thanks. I will. It runs now (i.e makes the requisite noises for 10 minutes) but does not seem to want to actually brew the espresso. Specifically, no water comes out, and I am worried to let it run due to the potential for wrecking the pump mechanism.
    Problem Solver:
  • 5 Answers
You may have blown a solinoid. You can send it to us for repair if you wish?
Posted on May 11, 2009
    Genius:
  • 1,199 Answers
Sounds like a leak..check the lines water may have shorted it out!
Posted on Dec 09, 2008
Expobar leaking steam
Where is it leaking steam from? If it is from the porta-filter, you need to replace the group head gasket, which is done with something like a screwdriver to get it out.
Feb 09, 2014 | EXPOBAR Office Pulser Espresso Machine
Expobar coffee machine very loud and no water coming out
It could be possible your water filter is in need of changing.
Feb 24, 2013 | EXPOBAR Office Control Espresso Machine
Expobar espresso steamer not working
The copper pipe the steam comes out of may be twisted it happened to mine.
Nov 30, 2012 | EXPOBAR Coffee Makers & Espresso Machines
Expobar steam wand loss of pressure
Are you leaving enough time for the water to heat up to a sufficient temperature? Typically 20 minutes is needed to ensure good steam flow.
May 25, 2012 | EXPOBAR Office Control Espresso Machine
We have an Expobar Office Control (Pulser) and while the machine pumps water it is not heating it and the red LED stays on. Any advice?
Hi
If its pumping water its not the thermal fuse. Its probably the heating element. If it starts to build pressure but stops, its your vacuum breaker. It could also be your CPU is bad. Need a little more information to get a better handle on it.
May 19, 2011 | EXPOBAR Office Control Espresso Machine
I need a Push-button Panel With Tea-program for
Check with espresssoparts.com. They carry a wide assortment of parts.
Oct 26, 2009 | EXPOBAR Office Control Espresso Machine
Can't get expobar office lever to start pumping water into boiler
You are right, there is no flange.Under the tank reservoir there is a switch (micro) if you lift the reservoir up you should hear the switch click on and off,.Sometimes the switch will hang up and stop the pump from coming on.Try that and let me know.
Thanks,
Sanremo
Feb 04, 2009 | EXPOBAR Office Lever
Machine working but not brewing coffee
Hi mate, Check the water - in pipe to ensure there is no blockages/. also check up around the group head to ensures old coffee ground have not been left there and gone hard.
Jul 31, 2007 | EXPOBAR Office Pulser Espresso Machine
EXPOBAR Office Control Espresso Machine Logo
230 people viewed this question
Top EXPOBAR Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an EXPOBAR Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
