Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Problems in A85
Recently, I found some problems in my Canon A85, 1. there are running lines with changing color on LCD display especially when viewing "dark" object. 2. the images taken are sometimes good, sometimes bad, e.g. a) purple sepia image or b) many horizontal lines distort the image. Anything I could do, please advise. My S410 just started doing this. A week before vacation! It appears that it is a similar issue, I emailed them about it. If you display images that existed on the card, they look fine. Anything new is a blurry image with ghosted vertical lines.
  • 2,039 Answers
It appears the CCD image sensor is going bad. Both these cameras are specified in Canon's technical notice regarding this issue. If Canon determines that this is the problem (and almost certainly it is), they will repair your cameras at no cost, regardless of warranty status. If you're not in the US, contact your regional Canon service facility.
Posted on Dec 09, 2008
Thanks for the advise about Canon's Technical Notice. Camera is on its way to repair for free. Problem: blury image at times.
Posted on Mar 03, 2009
The lcd monitor will display pictures taken on the disk already but whent taking a picture the screen is blank. I just changed the batteries.........
It is known problem of ccd imager chip failure in Canon A85 camera and Canon offers free of cost ccd imager chip replacement to fix it.
Click Canon CCD Imager Advisory for details.
Jun 30, 2010 | Canon PowerShot A85 Digital Camera
Hortizontial lines in LCD display.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 20, 2009 | Canon PowerShot A85 Digital Camera
Pictures turning out dark, LCD not adjusting
CCD sensor problems usually present themselves as either a blank image, purple cast, or lines through the image. Incorrect exposures are usually a result of the lens shutter failing to open and close correctly. Typically, the lens is not servicable and they need to be replaced.
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
Recorded image has horizontal lines/brown coloring
For the downloading issue, please see:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Apr 12, 2009 | Canon PowerShot A85 Digital Camera
Blurry LCD monitor in Canon PowerShot A85
Sometimes humidity is the problem . Please keep the camera under room temprature and on position for maximum time . For the Battery low problem first try using alkaline or lithium ion batteries and see if they work fine...
Oct 12, 2008 | Canon PowerShot A85 Digital Camera
Canon Powershot broken shutter/photo taking mechanism?
I hope you didn't chuck your camera, because this sounds like a problem with the CCD image sensor. I had the same problem with my Canon A85 and found out that Canon would cover the shipping and repair of the image sensor for FREE.
Please refer to this page, and then contact Canon (I reccomend calling; they're friendly, and the wait is not too incredibly long) to describe your problem. Make sure to mention that you believe the CCD image sensor is faulty, and you found the service notice they issued about the problem:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=10462&keycode=2112&id=48264
Sep 11, 2008 | Canon PowerShot A85 Digital Camera
LCD color get mixed
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is worldwide, and regardless of your camera's warranty status. Please check the following two links for more info:
Feb 06, 2008 | Canon PowerShot A80 Digital Camera
Problems in A85
This is a CCD sensor fault and you should find out from Canon if they will repair free of charge which they do on many models which have faulty sensor installed in the factory.
Sep 03, 2007 | Canon PowerShot A85 Digital Camera
Blank LCD works but wont display
I have a Canon powershot A85 camera, and it works fine, but I get no picture in the LCD screen. It does take pictures and I can look at the pictures after I have taken them. I don't know if you live in Australia, if you do ring Canon on 131383. A lot of Canon camera's and also a lot of other digital camera's all have a problem with the CCD Chip. My brother has a Canon A75, he has had is for many years, and they fixed it free of charge, because it is a problem the camera has, so not something we done. Look on the internet and you will find a lot of info on it, also that it will be fixed free of charge. I also found the same information on a lot of other digital camera's, so ring Canon and find out, I hope this helps you. Kind Regards Marion
Sep 20, 2006 | Canon PowerShot A85 Digital Camera
Blurry LCD
Canon S400 IXUS 400 ? Screen problems This is a known issue and Canon will fix it free of charge Go the the canon us or uk websites go to service then search for S400 (US) IXUS 400 (UK)
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
174 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
