Question about Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
No suction i have only used the floor cleaner/steamer a couple of times and now there is no suction. it does not suck up the dirty water from the carpet. any advice on how to fix this would be appreciated.
  • 1673 Answers
SOURCE: Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Posted on Feb 13, 2008
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
SOURCE: No power to head of Kenmore Progressive canister vac
I'm NO help but maybe you can enlighten me. Where IS the reset bugtton? The manual was lost in a move OR address to request a new manual. Thx
Posted on May 28, 2008
#1 Taper
  • 1040 Answers
SOURCE: My carpet shampooer has poor
Check to make sure that any/all intake vents are not blocked by debris. If that's o.k., then you need to replace the belt(s). Once the belts get stretched, they no longer work properly. This is normal and happens as a result of regular usage.
Posted on Sep 13, 2010
SOURCE: kennmore upright carpet cleaner model
Does not **** up water, I Lost manneul can you please give me directions on how to opperate
Posted on Oct 28, 2010
  • 4399 Answers
SOURCE: floor cleaner has no suction and carpet sequence
OK. Have you checked to see if your line is clogged?
Posted on Feb 23, 2011
0 characters
1 Points
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Why want my quick steamer suck up dirty water?
Check the manual for filters. They are generally small and need to be cleaned after each use. Consumer Care at 1-800-237-7691
Jul 19, 2014 | Bissell 1970-R Carpet Cleaners
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
It is not sucking up the water I have it together right, but I am not getting the dirty water out of the tank It is dry when the water is gone.
Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). It is a small (1 inch square) red plastic filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have proper suction once again.
Jul 12, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Hoover SteamVac Deluxe
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvan cleaner F5807
If this has a duct part #38661003 (#3) that is supposed to be installed in front of the tank isn't there, then you will have no suction to pick up the dirty water.
If this doesn't use a duct, then either the foam filter (#2) is up all of the way, need to leave 1/4 in. gap from the top, or the rear of the tank lid is not locked down.
Jan 22, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum Logo
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
