Question about Microsoft Windows Server Standard 2003 for PC
After installation new printer driver all client computer errors
Hi- I am new to this site. I am have no place to go that is why I really need your help.
My problem is that everytime I install one new shared printer on the server, I will receive complaints from the users that ALL printers are not working and needed to be reinstalled. Vista users will have the option to reinstall all the network printer drivers while XP users just needs to be deleted and re-added. Take note, this is for all printers on each users/computer. My printer server is windows 2003 standard edition with 4gb of RAM. I've been researching all over the net but no one can give me a good answer. Hope you guys can help!
  • Mark Dec 09, 2008
    Tried checking the event viewer and also check the print spooler services. I am running this server in a domain. I checked the groups policy and haven't seen anything mysterious. You guys know any thing in groups policy that might cause this issue?
  • Uwe Klopfer
    Uwe Klopfer May 11, 2010
    have you checked the logs on the server ?
    have you checked the print spooler service on the server ?
    the most likely cause is some sort of group policy config error.
    Are you running a domain or is your network peer-peer ?
  • 449 Answers
Reformat all your operating sytem and reinstall every driver you need to use. this is the only solution
Posted on Dec 09, 2008
How can i fix this problem in my flyff ph client its said ERROR: File Not Found CODE:0 RESULT:4 i really need your reply please i would be so greatfull if you help me with this problem.
Good day. For this kind of problem the only way to resolve it is to download the entire client again and have it reinstalled on your pc. Most client get specially after getting patch or updated in which the client itself encounters an error which cannot be solve even you try to patch the game. This are some tips to resolve your concern
Things to do:
1. download full client
2. uninstall previous client
3. delete the previous folder
4 restart pc
5.install the game
6 patch the game
7. restart pc
After this the game should work fine. Make sure that you have a recommended settings to avoid future problem. If this didnt resolve your issue you can check their official site for help. Hope this resolves your problem. Thanks for visiting Fixya and have a great day.
May 22, 2011 | Computers & Internet
Cannot Re-install my Lexmark 1200 Series Printer
frist of all u have to do this remove your printer from the control pannal go in add remove program remove your printer from there
then put your printer cd come with printer do not on your printer cd will be auto run then insall software during the installation your computer tell u power on your printer then u have on your printer power u will fienshed the setup
i hope this is help u
thnx using fixya
Jul 17, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
I can't install my Brother MFC6490CW printer onto
All these three methods involve some specific code in the printer drivers both in Print server and clients.
Not all printers will have drivers that will support all 3 ways of using the printer. It appears that not all printer drivers, written for Windows Vista. If you can't get your network printer, please try the following steps to bypass the LPT redirection. 1. Install the Vista printer driver on your Windows Vista computer.
2. During installation, you'll be prompted to connect the printer to your computer. Choose the option to proceed with installation without connecting the printer.
3. After installation completes, open the Printers wizard from the Windows Vista Control Panel.
4. Right click on the entry for the new printer, and choose Properties.
5. Go to the Ports tab.
6. Click Add Port, select Local Port, then click New Port.
7. For the port name, enter the network path and share name of your printer ("\\TheirComputer\TheirPrinter1").
8. Click OK, and verify that the new port is selected.
9. Click OK to close the printer properties.
May 22, 2011 | Acer Computers & Internet
When I start my computer I get a error: Error in
Based on the folders (spool/drivers) that sounds like the error is coming from a printer driver. Try uninstalling the last printer you installed and see if that resolves the issue.
If not, you can go into the Start Menu, under Accessories and System Tools and find the find the System Restore. When you installed the printer it should have created a Restore Point. Do a restore to that Restore Point, and it will take your systems registry and drivers back to the way they were before you did the driver update.
Once you have gotten rid of the error, by uninstalling ro restoring, then you may want to check the web site of the printer's manufacturer to see if there may be a new or corrected driver for the printer, and install that one rather than the one you used before.
Regards.
Jul 08, 2010 | Computers & Internet
Says I have no cam its built in how do I fix this problem when vista no longer see's it
I have dealt with this situation before on a clients laptop. You need to go into the device manager and verify its still installed or contains an error. If it shows that there is an error, you to the HP support site and download a new driver for your laptop's webcam. Installing a new version of the driver will help. If your computer doesn't know it has a webcam and puts the hardware under erroroness other in the device manager, the same solution applies. Contact me directly if you need more help.
Dec 20, 2009 | HP Pavilion dv9720us Notebook
Printer won't print anything.
Try to uninstall the drivers and turn off the printer. Then install the drivers back on and turn the printer back on. And then make sure this printer is set as default.
Mar 27, 2009 | Canon Pixma MP480 All-In-One InkJet...
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Microsoft Windows Server Standard 2003 for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
